Old March 31, 2013, 09:48 PM
LegendMask's Avatar
OK Guys, got my system running now, and bleeded all the bubbles I could get out of it.
fired my PC and quick OC on my CPU for a quick test on CPU and GPU for temperature, and the results are
Will drain the loop, next week and check the GPU Block and do a proper filling and bleeding.
Earth is Full, GO Home!!
eBay: kalsharabi - HeatWare: LegendMask - HWC: LegendMask
Old March 31, 2013, 10:14 PM
KaptCrunch's Avatar
wow 80 on gpu not good at all must be the mounting or forgot to remove film off WB
glad you got the loop burp'd
Old March 31, 2013, 10:17 PM
LegendMask's Avatar
it was a used GPU block, so for sure there was no film on it. the CPU though seems ok. It might be a bad mounting on the GPU part.
Thanks a lot for the help buddy, you did a huge help for me thanks
thanks thanks thanks thanks thanks a lot.
Old April 1, 2013, 06:12 AM
I wouldnt be running that pump on 1 dude... its too low.
Mah Rig now
Mah Rig before
My stuff for sale.
Old April 1, 2013, 07:04 AM
KaptCrunch's Avatar
for priming loop/pump you want it on the slowest speed so not to kill the ceramic bearings in pump
I find after primed 3-4 a good setting
Old April 1, 2013, 08:35 AM
LegendMask's Avatar
I was running it on (3) after putting the loop on the run.
OK guys, I drained my loop, first thing in the morning, and after taking the GPU out, as I was expecting ...ummm... will check the pictures
I dont know if its the thermal paste was little (which I doubt it), or I have the wrong screws size, because I have tighten the screws all the way down I even pushed it a little bit hard.
Old April 1, 2013, 08:47 AM
KaptCrunch's Avatar
looks need a copper shim .005 - .010 inch for thermal pads are too thick on ram, vrs
get yourself a dial vernier to check clearances
Old April 1, 2013, 09:01 AM
LegendMask's Avatar
but the thermal pads are the ones that came with the block, the previous owner even PM'd me telling me he was using it with no issue, and his load temp was 40C, when he saw my thread.
Im gonna try to add more paste this time, and check it if its enough before putting the gpu back in the loop.
one more thing, Im gonna use the same tubes, I dont think I have to replace them dont I? and just gonna get distilled water this time, while I search for killer coil.
has anyone tried the killer coil from dazmode? Im afraid its too small that it might get sucked in the loop/pump cuz Im using res and pump combo from XSPC 5.25 bay. I have read some horror stories about it.
  #19 (permalink)
Old April 1, 2013, 09:16 AM
KaptCrunch's Avatar
possible that your gpu is thinner then previous owner
  #20 (permalink)
Old April 1, 2013, 10:32 AM
LegendMask's Avatar
I added more paste this time, and tested it. I guess I had put very very thin layer the first time.
test result with a bit more thermal paste
gonna re-apply the thermal paste again tonight, but a bit little than the one in the test lol
MSI GeForce GTX 560 Ti unstable Grennum Troubleshooting 14 June 11, 2011 12:15 PM
Unstable i7 920 @ stock speed... Charloz24 Troubleshooting 15 April 16, 2010 07:42 AM
Once stable OC is now unstable? Fenrise Overclocking, Tweaking and Benchmarking 2 September 2, 2009 03:49 PM
Unstable i7 920 System NightRain CPU's and Motherboards 2 April 9, 2009 06:54 PM
BIOSHOCK PC - An Unstable P.O.C. ? DarKStar Troubleshooting 8 July 30, 2008 08:27 PM
