-   -   Regarding Thermal Pads on GPU Block (http://www.hardwarecanucks.com/forum/water-cooling/60456-regarding-thermal-pads-gpu-block.html)
LegendMask March 30, 2013 08:12 AM
is it possible to reuse it on VRAM? as I was starting to build my PC and install the water cool, I didnt notice the thermal pads were new, and now Im stuck since I tried since yesterday to find a local store that sells it, to no succeed.
they do seem still in new shape, except not sticky. (been used for two months based on previous owner).
if its a big deal, then my only option is to order it online and wait till at least wednesday :censored:
stephengillon March 30, 2013 08:41 AM
they should be fine, not as good as new of course but it will only be a small temp difference if any.
could always order new and use current ones and flush system out in month or two as it will sometimes find crud in the system even after flushing everything.
can put some non conductive paste on the pads if you have some just to play it safe
lowfat March 30, 2013 09:08 AM
Ya they'll be fine. They could be in very poor shape and still be sufficient for ram and VRMs.
LegendMask March 30, 2013 09:44 AM
Thanks for the response guys. Glad to hear its ok cuz I was pissed to hold off till at least wednesday. Will apply a very thin thermal paste on both sides to be safe.
Thank you so much guys.
