Old March 29, 2013, 12:16 AM
Just got the pics off my camera. Here's the pic of the loop setup that I originally wanted to have. This was pre-fill.
Keep in mind that this isn't the current loop setup, please see my build log for the most recent one (along with the explanation of why). I would like to switch back to the one pictured above, but would like some advice on the best way to fill and bleed the loop. No reservoirs, unless you can suggest a spot in the case where there's enough room. Oh, and no case modding either, I'd prefer not to cut anymore =). I don't mind paying for extra fittings & tubes.
Someone mentioned "add a t-block to the connection between the middle rad and bottom rad - right where the bottom compression fitting is. Flip the case upside down to fill. Use current GPU fill line, add a line to the t-block. Make sure tubes are extra long, hold them up high. This should allow air to escape through the t-block line. Clamp the lines when you're done bleeding, cut tubes and plug it up. I can see the logic here, but I'm not sure if it's the best path.
Any help would be greatly appreciated.
RFD Trader Feedback
My Heatware
Old March 29, 2013, 07:00 AM
KaptCrunch's Avatar
Originally Posted by mojojj View Post
No res, only a fill port connected to gpu block
TELL Gabe to sell one of these with his systems, china sells them real cheap nowadays
an with case laying on its side to burp top rad
all kidding aside pm me
for ["my fruits of labour"] its internet
the pic set-up would work great if was a desktop case (horiz MB)
Old March 29, 2013, 07:59 AM
What's the issue? Its going into the pump inlet.
RFD Trader Feedback
My Heatware
Old March 29, 2013, 08:06 AM
KaptCrunch's Avatar
look ygpm
Old March 29, 2013, 08:43 AM
KaptCrunch's Avatar
in the pic below the 9:00 clock positions is the outlet an this should be @ 12:00 when mounted in case to allow removal of air pockets in pump
so in tower the outlet should be on the left side of pump in vert position on horiz not an issue
wow just notice in pic the outlet is marked as in lol
with second pic for not having pump in hand an logic working
best place connections left to right with upper part of pump in tower set-up
Old March 29, 2013, 02:02 PM
kapt,\,
I'm having a hell of a time understanding your grammar.
are you saying that in the OP's pic, the inlet is higher than the outlet, but it should actually be the other way around?
Old March 29, 2013, 02:14 PM
KaptCrunch's Avatar
what saying is should mount pump with connections W-E not a N-S configuration
but some will argue, it don't matter what way you turn pump position
pic speak for themselves for pump innards need to be self bleeding (outlet @ top of impeller cavity)
now if swimming under water and you release gas.......what way bubbles go ?
same is you have a cup in hand by bottom of cup and a full sink of water
then place cup in sink upside down......if a hole was on the bottom of cup
what will happen .......self bleeding
Old March 29, 2013, 02:46 PM
KaptCrunch's Avatar
Originally Posted by Generic User #2 View Post
kapt,\,
correct after looking at h220 innards should be a west - east config with connections above rotor center
in a tower set-up to allow pump to self bleed
if were flat (desktop) no issues
my grammer is copyrighted
  #19 (permalink)
Old March 30, 2013, 07:05 AM
If it were me (assuming i'm looking at that picture correctly) I'd remove the middle rad and replace it with a micro res like someone else suggested. Am I seeing 3x 120 rads?
A/ it cleans up the build
B/ you won't get a vapour lock and have less expantion issues.
Mah Rig now
Mah Rig before
My stuff for sale.
  #20 (permalink)
Old March 30, 2013, 01:01 PM
Makes sense. I can give this a shot. Thanks.
RFD Trader Feedback
My Heatware
Im bleeding. NSFW! Alpine Off Topic 25 November 9, 2012 10:27 AM
Quick Question about Bleeding b1ack1otus Display Units 6 October 6, 2012 03:56 PM
Bleeding swiftech mcres v2 geoc Water Cooling 13 September 30, 2012 12:46 AM
tri-fire loop, filling/bleeding vinister Water Cooling 17 May 18, 2008 10:30 PM
filling, bleeding and testing new loop magictorch Water Cooling 25 April 10, 2008 02:35 PM
