Old March 30, 2013, 12:48 PM
Datavac is the way to go. I bought mine pricematched from Tigerdirect a year ago for less than $100. You should be able to find good deals every now and then. Highly recommended.
Old March 30, 2013, 12:57 PM
Hooded's Avatar
Originally Posted by Desiato View Post
There's always a risk of damaging electronics with a conventional vacuum via static. I have no idea how likely it is. There are ESD-safe vacuums made for electronics.
Menda 35849 ESD Safe Omega Vacuum Field Cleaner Kit: Amazon.com: Industrial & Scientific
Oh man you need to wear a hardhat to use that suck a. According to the PPE list anyways.
F120 bit the dust grinder Storage 1 August 8, 2012 05:32 AM
Dust 514 bissa Gaming 8 March 31, 2012 10:14 AM
My PS3 just bit the dust! cb2222 Gaming 20 September 8, 2009 06:52 PM
The Dust Box JayDee Cases 12 August 2, 2007 02:46 PM
how to get rid of dust? magictorch Water Cooling 12 July 2, 2007 07:59 PM
