Old March 25, 2013, 05:55 PM
Default How do you guys plan your WC loops in terms of fittings?
Hey guys. So Ill be using Bitspower Matte Black fittings (would use Carbon Black but they're not available in the US).
I will be using Primochill Primoflex Advanced LRT clear tubing, as well as Mayhem's Blue Berry Pastel coolant (not a dye).
How do you guys go about planning your WC loops in terms of how you guys set up the fittings? Im trying to visualize how I want my loop to look, but since it's my first time, Id like some insight.
What are some do's and don'ts with fittings, what would you guys recommend?
Old March 25, 2013, 06:07 PM
ZZLEE's Avatar
45 and 90 degrees rotary are real useful in tight cases. the rotary gives you play in your loop.
Its always nice to have fitting and not need them all.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 25, 2013, 06:16 PM
nasrott's Avatar
I bought like 6- 4 pack 360 degree 45' compression elbows plus a few extensions when I did mine. 2 make a 90' plus swivel or just 45's on there own idea. Extensions used so in/outputs on the rad didn't hit each other idea when leaving horizontally. Plus had straight compression fitting from original kit. One rad you'd need less though. If you draw out your loop front and top view idea it would give you a better idea of the fittings you need.
Old March 25, 2013, 07:27 PM
lowfat's Avatar
In a perfect world you would have all your hardware before you buy the fittings.
Always buy one or two more than you think you'll need. It would be a good idea to buy a couple more 90 degree rotaries than you think you'll need. Now saying that you likely don't NEED rotaries at all. I really don't get the current trend of 45 degree rotaries all over the place. Things tend to look cleaner w/o them. With a pot of hot water and some rope you can get some great bends out of tubing. Sleeving Discussion & Gallery thread
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 25, 2013, 07:58 PM
nasrott's Avatar
Was wondering how you did that, thx lowfat, love the sleeving over the tubbng.
Old March 25, 2013, 08:04 PM
I want a very clean looking loop, no ridiculously long routes, great circular bends. Some people go crazy and it looks terrible.
Old March 26, 2013, 06:46 AM
lootbag's Avatar
For my first watercooling build, I bought all the hardware first and a small amount of fittings so I could test fit and visualize how the tube bends were going to go.
Then, I made a second order with all the fittings needed.
It is hard to know what fittings you'll need until you have tried bending the tube with fittings attached to components.
Old March 26, 2013, 09:01 AM
KaptCrunch's Avatar
this is a no no..... using a 90 elbow on pump suction port
Old March 26, 2013, 03:24 PM
Astaroth's Avatar
I like my angled adapters, better than angled compressions IMO. Boiling and bending doesn't always cut it. Primochill Advanced isn't as bendy as their pro variety. As mentioned always get more fittings than what you think you will need, and a good tube cutter is your friend. Lastly, as long your reservoir is placed before your pump, do what you want.
Old March 26, 2013, 05:22 PM
Bloodystumps's Avatar
I usually get stupid drunk and just smash shit into the case.... but before I do that I plan it out with sketchup and then dry fit everything.. then resort to my first statement
The cause of the GUM in our loops Lanboy Water Cooling 14 June 12, 2011 06:13 AM
Dual loops or no? Prolab Water Cooling 11 January 27, 2011 11:47 PM
Two Loops? Infiniti Water Cooling 10 June 16, 2008 09:32 AM
A short guide to memory terms from maxitmag Babrbarossa RAM 2 May 15, 2007 07:05 PM
