-   -   Does anyone else hate draining their WC loops? (http://www.hardwarecanucks.com/forum/water-cooling/60362-does-anyone-else-hate-draining-their-wc-loops.html)
Soullessone21 March 24, 2013 09:25 AM
I have to get all my systems apart and gone today but Draining my main rigs look is making me procrastinate so bad.
Wanted to know if I was just crazy or is more people out there the same way.
PS the Seidon 240m is next to impossible to mount in most my cases :S:(
lowfat March 24, 2013 09:40 AM
Have to drain my loop today. However w/ my bench it really is easy and hassle free. I am a big fan of drain plugs in easy accessible locations.
LegendMask March 24, 2013 10:19 AM
by the end of next week I should start my first WC Build, and draining port is gonna be on the MENU :bananafunky: I just hope I wont screw it up. :biggrin:
KaptCrunch March 24, 2013 10:43 AM
easy Soullessone21
large catheter syringe with hose on end to suck the fluid out
http://www.melbournefooddepot.com/as...ull/F06030.jpg
Capt Proton March 24, 2013 10:57 AM
One of my rads is the highest component, so I have to take everythign out to refill.
Oh yeah, no res either, so I put the liquid in using a syringe through the bleed screwhole in my PA 120.2.
Astaroth March 24, 2013 12:47 PM
Only drain when I get the upgrade itch or adjust my loop. Drain ball valve at the lowest point in my loop does the trick. I only ever use distilled so I don't have to worry about anything getting stained. I use wax paper to prevent water from getting anywhere inside my case. Release the valve and let the good times roll.
Bloodystumps March 24, 2013 12:58 PM
I don't mind it only takes less then 5 minutes on my gaming rig to drain and refill and maybe another 2 minutes to bleed.... no drain ports just a external 500ml res... HTPC can be a little more of a process but still less then a 20 minute procedure and I just put a drain in that one....
Hopefully I can keep the simplicity in tact on my gaming rig once I change everything up, well if I ever change it up I need a couple of things and don't want to pay brokerage fees and Daz only stocks EK junk
dustin1706 March 24, 2013 09:48 PM
I don't have any drain plugs/ports on either loop. I just pop a hose out of a fitting and hold a large cup under the fitting and hose. Takes longer to unhook all the rear cables and put the pc on a table than it does to drain.
mataribot March 25, 2013 07:35 PM
I would rather drain than fill. Just use a squeeze bottle such as a dish soap bottle and attach a small piece of hose attached to it. Squeeze the bottle, place the hose in the reservoir, and slowly let go... I use this method to drain part of my loop to add new blocks. Yes I wm that lazy
lootbag March 26, 2013 09:12 AM
Interesting technique mataribot haha!
Going to try that one day.
