Old March 18, 2013, 10:59 AM
Default What kind of tubing and fittings are compatible with the XSPC Raystorm?
Hello all. I will be getting Bitspower Carbon Black fittings. The XSPC Raystorm uses "1/2 x 3/4" fittings, I'm assuming that's 1/2 ID and 3/4 OD?
Does that mean I can ONLY use 1/2 ID 3/4 OD tubing and fittings..?
XSPC RayStorm High Performance Acetal CPU Liquid Cooling Block - Intel (Sockets LGA 1155 / 1156 / 1366 / 2011) - FrozenCPU.com
Bitspower ? Future Design Unique
Also, what do the O rings accomplish, and will they show..?
Old March 18, 2013, 11:13 AM
SugarJ's Avatar
Actually, what it says is that the block is compatible with 1/2x3/4 compression fittings. It means the holes are far enough apart that you can screw in 2 of those big fittings without having to use an elbow. It can be used with ANY G1/4" fitting size. And G1/4 is the standard that all fitting makers use.
The o-rings make the seal between the block and the fitting. It's what makes it watertight. I've never been able to see them on any of my fittings once they are tight.
Old March 18, 2013, 11:39 AM
Keltron 3030's Avatar
Correct, and trust me when I say that knowing this information beforehand is a godsend.
Over the summer, I changed all my fittings to compression, and I found out AFTER I bought everything that my GPU block does not play well with straight compression fittings Luckily I had some 45's and 90's bought as well to compensate for the problem, but if I had of known this beforehand, I would of re-planned my tube route.
FFFFFFFUUUUUUUUUUUU-
Old March 18, 2013, 11:41 AM
So what does 1/2x3/4 mean exactly? Your post is confusing me.
What's the most common ID and OD? I want really high quality clear tubing since I'll be using Mayhem's Blue Berry Pastel, need it to show perfectly.
Old March 18, 2013, 12:25 PM
SugarJ's Avatar
1/2x3/4 refers to 1/2" ID x 3/4" OD. ID is inside diameter, OD is outside diameter.
As for what's the most common? Probably 3/8"ID. It's been proven that there's almost no difference in cooling capacity in most loops between 3/8" and 1/2" ID tubing, so it's simply a matter of which you think looks better. I like the big tubing myself.
Old March 18, 2013, 01:03 PM
LegendMask's Avatar
I asked Daz few days ago the same question, and his response was
Tube and fitting 3/8-5/8 size.
You need two extra fitting per gpu block. Tube you may or may be not need extra.
Daz
After-hours Customer Support
Sent from iPad (text mode only)
Earth is Full, GO Home!!
eBay: kalsharabi - HeatWare: LegendMask - HWC: LegendMask
Old March 18, 2013, 02:34 PM
Originally Posted by Reaper2794 View Post
...I want really high quality clear tubing since I'll be using Mayhem's Blue Berry Pastel, need it to show perfectly.
I would suggest you start off with distilled water first. Drain it and switch to the good stuff once you confirm that everything is working exactly as you want. You don't wanna go wasting the pre-mixed fluid
RFD Trader Feedback
My Heatware
Old March 18, 2013, 06:24 PM
Yeah I'll clean it with water, try with distilled then get the Blue Berry Pastel.
Is the Primochill Advanced really that good? What makes it good?
Old March 19, 2013, 07:37 AM
So if any G 1/4 thread fits, what's the 1/2 x 3/4 for?
Old March 19, 2013, 09:14 AM
Compression fittings are bigger than normal barbed fittings, and are specially made for different sized tubing. 1/2 x 3/4 is the biggest sized tubing available. This means it can accommodate compression fittings for that tubing size without the two fittings interfering with one another.
Fittings and Tubing questions Keltron 3030 Water Cooling 5 June 27, 2012 03:52 PM
[WTB] LF: 3x12 Radiator, 1366 WB, Pump, QUIET fans, tubing, fittings, res n-sanity Buy/Sell & Trade 0 December 14, 2011 02:24 PM
Quick question on UV and fittings/tubing Patlabor Water Cooling 7 March 4, 2010 03:14 PM
How do I tell if my components are compatible with compression fittings? Z Overlord Water Cooling 9 October 12, 2009 05:36 PM
