Old March 19, 2013, 09:15 AM
SugarJ's Avatar
The G1/4 side screws into your block or elbow. The 1/2" Inside Diameter x 3/4" Outside Diameter refers to the size of tubing that fits in the compression side of the fitting. If you look at 3/8" ID compression fittings you'll see 2 sizes of OD, 1/2" and 5/8". It's very important you get the same size as your tubing or they either won't fit or won't seal.
Old March 19, 2013, 03:16 PM
What tubing would you recommend?
Old March 19, 2013, 04:12 PM
I think most guys go with primochill... some stuff has better bend radius than other stuff so it really depends on what you want. I'd highly suggest as a 1st timer... going to the hardware store and buying cheap tubing the same size to practice with... 10 bux of that will probably do your entire loop. Once ya getter setup just the way you want you can then use those cheap assed pieces to measure and cut your good stuff.
nothing worse than wasting expensive tubing man.
Mah Rig now
Mah Rig before
My stuff for sale.
Old March 19, 2013, 04:22 PM
I plan on going with the Primochill Advanced LRT Crystal Clear
I don't think I'll end up wasting that much tubing, it can't be too hard getting the right measurements.
Plus I live less than 10 miles away from Frozen CPU
Old March 19, 2013, 05:12 PM
Bungwirez's Avatar
that's lucky. just curious, do these guys have helpful sales staff up front?
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old March 19, 2013, 05:16 PM
Have only been there twice, gonna go soon to get some inspiration and ideas and check out some parts, ask for some info. Never handle any liquid cooling parts.
I shook hands with the CEO, huge ass dude lol. He was nice, their staff is pretty good too. Will have to talk to em more when I go sometime this week.
Fittings and Tubing questions Keltron 3030 Water Cooling 5 June 27, 2012 03:52 PM
[WTB] LF: 3x12 Radiator, 1366 WB, Pump, QUIET fans, tubing, fittings, res n-sanity Buy/Sell & Trade 0 December 14, 2011 02:24 PM
Quick question on UV and fittings/tubing Patlabor Water Cooling 7 March 4, 2010 03:14 PM
How do I tell if my components are compatible with compression fittings? Z Overlord Water Cooling 9 October 12, 2009 05:36 PM
