Old March 18, 2013, 09:55 AM
LegendMask's Avatar
Default WC Loop/Parts plan Check?
First time building a WC and I wanna make sure I have no mistake before placing my order or if Im missing/doing something wrong
Please post if something wrong or missing or even a suggestion.
First of all Im planning to water cool the CPU +GPU with drain port.
Second: the loop plan
Lastly the parts list check
- XSPC RX360 D5 Kit
- 4ft 3/8"ID - 1/2"OD Tubing (is it enough?)
- 8x 3/8"ID - 1/2"OD Straight Compression Fitting
- 3x 3/8"ID - 1/2"OD Rotary 45 Deg. Angled Compression Fitting -Black
- 1x 3-way Splitter, T Block Crossconnect Adapter - Black BP-MBTMB (do I need special adapter before connecting it to a compression fitting?)
- 1x Fill/Drain Port Sealing Plug w/ 3/8"ID Tubing Barb - Matt Black
Thanks...
Earth is Full, GO Home!!
eBay: kalsharabi - HeatWare: LegendMask - HWC: LegendMask
Last edited by LegendMask; March 18, 2013 at 11:34 AM. Reason: switched from Y adapter to T-Block
Old March 18, 2013, 10:39 AM
SugarJ's Avatar
That Y fitting will restrict the flow big time as drawn. Use a 90 degree T like this: 3-way Splitter, T Block Crossconnect Adapter - Black BP-MBTMB The fittings screw right into it.
And 4' of tubing is not enough. It's cheap, get 8-10'.
Old March 18, 2013, 11:32 AM
LegendMask's Avatar
10' it is, and Im switching to the T Block. Thanks a lot for the tip
Old March 18, 2013, 01:05 PM
LegendMask's Avatar
could someone answer my question above if its possible? since Im planning to order it hopefully tomorrow.
thanks
Old March 18, 2013, 02:20 PM
thanks
Not too sure what adapters you're referring to, but if you want to put just compression fittings on it then it's no problem.
And yes, you can put any manner of adapters on it as long as they're G1/4 threaded. IE. you want to put angled adapters.
RFD Trader Feedback
Old March 18, 2013, 02:41 PM
SugarJ's Avatar
I did answer.
Old March 18, 2013, 02:54 PM
LegendMask's Avatar
I did answer.
God damn it, working and reading at the same time!! Skipped the most importnat thing I even had emailed Daz!! My bad Sugar :)
Finished work time to go home :p
Thanks a lot for the help guys, I guess im ready to place my order.
Old March 18, 2013, 03:59 PM
Bungwirez's Avatar
lol. I place all my orders to Daz from work. :P
If you don't like funerals, don't kick sand in Ninja's face
Old March 18, 2013, 04:40 PM
LegendMask's Avatar
LoL, try doing it while there is a conference going on, and working 8-12 hours a day, going for 13 days straight including weekends, no off.
cant wait till Im done and start my build by the end of the month
Old March 19, 2013, 12:56 PM
LegendMask's Avatar
sorry guys, another question Im concerned about the drain port.
Im gonna be using this Fill/Drain Port Sealing Plug w/ 3/8"ID Tubing Barb - Matt Black
do I need Tube Clamps when connecting the tube to that port? or just connect the tube by itself and lock/seal the other side with the cover?
Price check on all parts undeclared Price Check 0 August 20, 2012 11:11 PM
old parts price check snagglepuss Price Check 2 March 31, 2012 03:48 PM
Price Check old parts Aimbayya Price Check 4 November 30, 2011 10:45 AM
dual Gtx 480 wc loop plan Whoopyour Water Cooling 18 March 29, 2010 09:44 PM
Looking for ideas on parts. Been outa the loop for a long while! Black_Ice-Dragon New Builds 24 April 17, 2009 02:20 PM
