Old March 19, 2013, 02:03 PM
You'll need a clamp. That fill/drain port is essentially a barb with a stop plug on the other end.
RFD Trader Feedback
My Heatware
Old March 19, 2013, 02:30 PM
SugarJ's Avatar
Or you can just put a stop plug in the T if you don't need a tube running off of it.
Old March 19, 2013, 05:55 PM
lowfat's Avatar
Originally Posted by LegendMask View Post
do I need Tube Clamps when connecting the tube to that port? or just connect the tube by itself and lock/seal the other side with the cover?
You would be safe not using a clamp here. 3/8" tubing is extremely tight over a barb like that.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 19, 2013, 06:42 PM
LegendMask's Avatar
Thanks a lot for the help guys
Im about to place the order, just adding the items on my cart and checkout.
Picked up Feser One Cooling Fluid-Pure, is it good?
Earth is Full, GO Home!!
eBay: kalsharabi - HeatWare: LegendMask - HWC: LegendMask
Old March 19, 2013, 07:15 PM
small peice of advice with the tee fitting. Don't dead head it. If this " T " was your fitting the drain port would be out the bottom. Good luck with your build man! Water cooling is a fun yet pricey hobby.
Probably gonna swing by Daz's site right now ffs...
Mah Rig now
Mah Rig before
My stuff for sale.
Old March 20, 2013, 04:45 AM
LegendMask's Avatar
tell me about it, I was planning to spend $300-350, ended up spending around almost $570, but still looking forward to it
Price check on all parts undeclared Price Check 0 August 20, 2012 11:11 PM
old parts price check snagglepuss Price Check 2 March 31, 2012 03:48 PM
Price Check old parts Aimbayya Price Check 4 November 30, 2011 11:45 AM
dual Gtx 480 wc loop plan Whoopyour Water Cooling 18 March 29, 2010 09:44 PM
Looking for ideas on parts. Been outa the loop for a long while! Black_Ice-Dragon New Builds 24 April 17, 2009 02:20 PM
