oh, forgot to mention 2600K. I would be terrified of doing this on Ivy bridge :/
currently have the D14 with ULN A15(push - it's technically on the case slot, but it's physically pressed against the D14) and ULN F12(middle). It hit 80 celsius at 4.4Ghz with 1.336v after 15-20 minutes running prime. fans running at 100% of course. Was having a little bit of trouble with setting voltage (auto voltage is sooo bad) so I gave up until I find some tweezers to adjust my fans.
normal day-to-day, I get about 4-10% of 4.4Ghz cpu usage and temps hover at 35 while web browsing, wildly swinging from 42-47 watching vids.
based on my room, with a sg07, 13 noctua decibels is too loud and 10 noctua decibels are tolerable. Not sure how well this case holds in noise relative to the sg07 because I 'setup' the hardware for overclocking rather than it's more permanent silence-first setup.
all in all, I THINK staying between 50-70 for my regular tasks should be doable with h90 with the ULN A14. I'd even be willing to undervolt and keep stock speeds (I've never seen my CPU hit even 20% usage outside of benchmarks and spikes occasionally during games).
EDIT:
I'm honestly not sure how to read ASUS fanxpert readings. It says that the motherboard is 40-50, but what is that sensor measuring exactly?
