Old March 17, 2013, 03:38 PM
LegendMask's Avatar
Default Buying Raystorm D5 Kit help
Im planning to get the XSPC Raystorm D5 Kit, and as you may know it comes with the fittings and tubing sized 3/8 ID and 5/8 OD.
now my question is, if I decided to go with different size fittings and tubing lets say (ex. 3/8 ID and 1/2 OD) would this work? and have no issues with fitting them in the RAD, CPU Blocks and GPU Blocks? or am I missing something.
thanks
Earth is Full, GO Home!!
eBay: kalsharabi - HeatWare: LegendMask - HWC: LegendMask
Old March 17, 2013, 04:22 PM
Bloodystumps's Avatar
Nope you should have no problems at all, the XSPC kit should be G1/4 on all the blocks and rads....
Old March 17, 2013, 04:29 PM
sswilson's Avatar
Just keep in mind that upgrading fittings for a whole loop can be quite pricey, so if it's something you plan to do immediately you might want to look at a different kit which has the fitting size you want.
Old March 17, 2013, 04:39 PM
LegendMask's Avatar
thanks for the response, but what is G1/4? is it the ID or what? because I really dont know what it is.
Im really thinking about it, but Im not planning to get expensive fittings probably one of those ~$5 fittings.
the thing is (please don't laugh ) I really want the the white tubing and white/light blue UV tubing and for the love of god I cant find it on 3/8ID and 3/5ID, and I cant find XSPC fittings with 45 or 90 degrees fittings.
Old March 17, 2013, 04:52 PM
G 1/4 is the standard thread size on the Blocks and rads were the fittings screw in...
Edit: I went and found a picture of a G1/4 thread so you can see were on the fitting it is..
Tubing like this ??? https://www.dazmode.com/store/produc...e_1ft_-_white/
Old March 17, 2013, 05:25 PM
LegendMask's Avatar
Man how can I thank you? thats all the information I really need now. Seriously thanks a lot
nope, its missing the white UV. I guess I have no choice but to forget the white UV and stick to White tubing, if Im getting the Kit.
something like this in the video UV Watercooling Tubing review for DazMode - YouTube
Old March 17, 2013, 05:51 PM
ah cool, well maybe you should ask Daz if he could order some in for you.....
no problem that's how we learn by asking right??
Old March 17, 2013, 06:08 PM
LegendMask's Avatar
Yes indeed buddy.
I have asked him already, and pointed me towards the one available already, only white tube.
Old March 17, 2013, 06:18 PM
If you use 3/8 ID barb fittings you can change between any 3/8 ID tubing later. So like 3/8ID 5/8OD and 1/2OD will all work on the same barb style fittings. You only need to worry about the outside diameter if you use compression fittings.
People sell fittings for good prices on the buy/sell forum all the time too... sometimes you can get good deals there.
My stuff for sale.
Mah Rig
Old March 17, 2013, 07:49 PM
LegendMask's Avatar
thanks for your input guys, I missed some deals on BST.
But anyway, I gotta decide by next week because by the beginning of next month I have plenty of time to start my build, so I hope I can gather all the parts by that time.
buying new pc netgears New Builds 7 August 9, 2012 04:48 PM
dazmode raystorm RX360-D5S kit r3v07ut10n Water Cooling 17 March 20, 2012 07:45 PM
New Rasa RayStorm CPU Block jdm89 Water Cooling 24 December 15, 2011 11:13 PM
Buying a TV Gregole Display Units 20 November 7, 2011 03:22 AM
[WTB] Buying a SSD, PM me THS Buy/Sell & Trade 0 July 25, 2011 01:15 PM
