Old March 15, 2013, 06:46 PM
Originally Posted by Mark View Post
Yeah, I'm leaving it right side up. Drilled a 1/8" whole and glued in a brass bolt with J-B Quick weld compound. Then thread in a screw with an O ring and some Loctite..then I'll test it :). This is the lowest point so I will have 90 % of the water drained from there. My XSPC reservoir is the next item that needs a proper drain but that will be much easier since it's thick Lexan by the looks of it.
That's 2 of 10 problem solved. :)
I honestly wonder why they don't make most rads like this already dude. They should have ports on both sides to make this process a no brainer.
My stuff for sale.
Mah Rig
Old March 16, 2013, 08:35 AM
KaptCrunch's Avatar
Mark best solder on your brass/copper nut to rad or use plug
after time JB weld comes loose
Old March 16, 2013, 01:03 PM
Mark's Avatar
I don't weld and dont think soldering would of worked ?
I used the JB weld but I can take it off with allot of elbow grease...stuff is tuff to remove. You think soldering would work ? how so ? only using 1/8" of a whole.
CHEERS
Old March 16, 2013, 04:48 PM
If you clean off the paint around the hole and sand it nice and clean/sand the brass fitting. Yes it will work. Assuming you know how to solder I'll leave it at that.
My stuff for sale.
Mah Rig
Old March 16, 2013, 06:23 PM
Mark's Avatar
You are right . That binding glue is not very good at all. Took out my flux, sanded the area and used plumbing solder. Much stronger now . Just finished it with a coat of clear lacquer but not on the fins. Should be good to go. I also used removable thread lock with the copper screw.
CHEERS
Old March 16, 2013, 08:14 PM
t-tape is probably enough for that too. +1 for the soldering ;)
My stuff for sale.
Mah Rig
Old March 17, 2013, 07:18 AM
Mark's Avatar
Here's the finished rad. Took off all the surrounding paint and went old retro with a 2 coats of lacquer...but did not touch the fins at all.
Could of made the solder prettier but wanted a good glob and it to sink properly...better safe then appearances.
CHEERS
Old March 17, 2013, 08:07 AM
KaptCrunch's Avatar
practice makes perfect you need a little more heat on the nut, looks cold soldered
best is pre-tin the nut before mounting on rad (have correct tap to clean threads after soldering on rad)
then same with rad hole area, if using propane torch
have rad in a metal bucket of water covering to rad tank joint (verticle)
so not to melt its joint
now you can sleep at night
note: with propane torch will have to re-finish tank after
if use a electric iron, 125watt for best results
  #19 (permalink)
Old March 17, 2013, 08:21 AM
Bloodystumps's Avatar
That sure does look like a cold soldered... Sounds like KaptCrunch has done this before
  #20 (permalink)
Old March 17, 2013, 09:15 AM
KaptCrunch's Avatar
i'd use this to bleed air out, add clear hose to rez (at highest point of loop) an snap open/close with pump running till steady flow
Advantage of "upside down" power supply? Evil Genius Jr. Cases 11 January 3, 2013 12:50 AM
Graphics card upside down W4ff1e Video Cards 14 June 7, 2012 07:06 PM
Installing QP-Res upside down? sswilson Water Cooling 22 February 22, 2009 05:48 PM
