Old March 15, 2013, 09:48 AM
KaptCrunch's Avatar
Originally Posted by great_big_abyss View Post
Shouldn't apply, since it's a closed system. Theres's the same amount of water going 'down' as there is going 'up'. The weight of the water going 'down' cancels out the weight of the water going UP, therefore head calculations don't figure into it. The only thing the pump has to overcome is the friction of the water against the tubing walls, and the pressure created by the blocks.
Certain things are always true with centrifugal pumps
pumps simply will not deliver to heights above their rated head, and delivery falls off rapidly as max head is approached. Small tubing and tight bends just add insult to injury to delivery rate.
now if were talking displacement pump (gear/vane) i agree
Old March 15, 2013, 10:08 AM
great_big_abyss's Avatar
The type of pump has nothing to do with it. There are four kinds of head: Static Head, Friction Head, Pressure Head, and Velocity head. So, just to make sure we're talking about the same thing...
Static head represents the net change in height, in feet, that the pump must overcome. It applies only in open systems. In a closed loop, the static head is zero because the fluid on one side of the system pushes the fluid up the other side of the system, so the pump does not need to overcome any elevation.
Friction Head (aside from being the type that Perinium's mom is best versed in) is also called pressure drop. When fluid flows through any system component, friction results. This causes a loss in pressure. components causing friction include rads, tubing, blocks, etc. The pump must overcome this friction. Friction is usually expressed in units called 'feet of head'. A foot of friction head is equal to lifting the fluid one foot of static height.
Pressure Head exists when liquid is pumped from a vessel at one pressure to a vessel at another pressure.
Velocity Head exists when accelerating water from a standstill or low velocity at the starting point to a higher velocity at the ending point. In closed systems the starting point is the same as the ending point. Therefore beginning velocity equals the final velocity, so velocity head is not a consideration.
In a PC watercooling application, Friction Head is the only head that must be accounted for. The pump must be strong enough to overcome the friction resulting from the tubing and all the peripherals (blocks, rads, res, etc). Add more tubing (to run to a cold room) and you'll add more friction, possibly necessitating a larger or second pump.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old March 15, 2013, 11:56 AM
KaptCrunch's Avatar
and head shut off is inherant of centerifugal
positive pump has no shutoff head like centrifugal pumps.
with at most computer cases loop elevation max 3ft where laing ddc has 13ft of head on 3/8 barb's
now go outside of 13ft = no flow head shut-off point of pump
Old March 15, 2013, 06:59 PM
same as linar if were on same floor
so would need second pump along loop before 10ft head mark
Water exterts no pressure horizontally... only vertically dude. There might be a bit of static load but most pumps can deal with this. It also doesn't matter how big or small the container at the top or bottom is the weight of water never changes if it is above 4 degrees C. And exactly what Abyss said... what goes up must come down so it cancels out.
Water weighs .433 pounds per square inch per foot of height. You are correct about the head pressure... if you can only get 10 feet of head pressure and you have to go 11 feet you will have zero pressure. You can solve this problem by putting another pump back to back if you choose to increase head pressure or you can purchase a better pump.
If you need 10 psig to go 10 feet up and require 10psig at the top of 10 feet you need a pump that does 20psig. If you wanna get really technical you can also add in pressure reducing valves and an expansion tank and throw a bigger pump at it... hell throw in a lift check valve while your at it. :P
*had to fix my math there... I'm tired.
My stuff for sale.
Mah Rig
Old March 15, 2013, 07:04 PM
use a filter same with PVC tubing
You do NOT want to deal with this stuff man... Pex is a FAR better solution and much cheaper.
My stuff for sale.
Mah Rig
Old March 16, 2013, 04:45 AM
Hooded's Avatar
Pex is far more expensive than the tube I posted. Also the tube I show doesn't require any Pex fittings. It works just fine with standard water cooling fittings. And it's not actually cheap so much as inexpensive.
Old March 16, 2013, 08:08 AM
KaptCrunch's Avatar
yes your pump is rated by kinetic energy of 10ft
that is all it can move from the rotor/impeller
Old March 16, 2013, 05:10 PM
LOL... dude have you EVER used that stuff on long runs? It's pure garbage. Pex isn't that expensive even the fittings are cheap. $0.30-1.00 / foot tops man. That stuff isn't as cheap as you think and it's a nightmare to work with... half the time it's flattented out when you buy it.. pex never flattens out.
My stuff for sale.
Mah Rig
  #19 (permalink)
Old March 24, 2013, 11:03 AM
I have found with water cooling that cheap is not necessarily the same as good value.
i7 3770K, 4.7GHz at 1.33V, ASROCK Z77 Extreme4, 2X4GB Patriot Viper Black Mamba DDR3 1600, GTX 590, 2 Corsair Force 3 120GB SSDs RAID 0,2 Barracuda 7200.10 500GB, Barracuda 7200.11 1000GB Back Ups, OCZ ZX 1250W, Z-5500s, LG Blu Ray Player/DVD Burner, Windows 7 X64 Pro, HAF X. Vision Quest 24" LCD, Optoma H66 Projector
Cooling: TC PA120.2 GT AP15 in push, DDC 3.25/XSPC Res top, EK Supremacy, XSPC Razor, Coolgate CG-240 Swiftech Helix in push/pull, MCP35X
[WTB] Swiftech hose clamps... freeloader1969 Buy/Sell & Trade 5 June 4, 2010 05:30 AM
Hose staining? frosty Water Cooling 14 January 25, 2010 09:54 PM
How do you guys cut your hose? rai_polo Water Cooling 30 November 1, 2009 11:51 PM
wormdrive hose clamps nikitos Water Cooling 6 June 19, 2008 11:16 PM
