Old March 12, 2013, 08:47 AM
mchutch's Avatar
Default Cleaning Questions
One year since my custom water build.
What do you guys clean your rads with?
What about CPU, GPU and chipset blocks? They are all nickel plated with plexi tops.
What about acrylic reservoir?
Just looking for advice, not to damage anything, do somethings not need cleaning etc..
All I used was distilled water.
Old March 12, 2013, 08:56 AM
SugarJ's Avatar
Just change the water, unless you can see buildup on the blocks. If it's a tube style reservoir, I disassemble and wipe the acrylic down.
Old March 12, 2013, 09:05 AM
canada2005's Avatar
Clean the rads with a vinegar and water 50-50 mix.
Clean the tube res with just water and a wipe, dont let it touch any vinegar.
Old March 12, 2013, 09:53 AM
Shadowmeph's Avatar
I just fill my res up and have very last hose of the loop inside a bucket fire up the pump on high then just keep topping up the res mind you I don't do it that often becasue I look at my res to see if there is any floaties in there and I have only seen floaties once
Old March 12, 2013, 09:54 AM
mchutch's Avatar
Default cleaning
I have quick disconnects for the dual 5.25 bay pump & res combo, so I can quickly clean that apart from the rest of the loop.
Here is a pic of the 680 block, sorry for size but might be hard to see but there is some cloudiness it seems on the plexi, and some discoloration on the nickel.
Anything to clear or lessen this?
Old March 12, 2013, 09:59 AM
mchutch's Avatar
Default cleaning
That's what I usually do but this time I'm getting new tubing so it's all apart and I'm focusing on what to use to clean rads and blocks without wrecking anything..
Old March 12, 2013, 10:53 AM
lowfat's Avatar
Are you comfortable opening up the block? I am not aware of anyway to clean that block w/o risking damaging it. Not without opening it up and cleaning it by hand.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 12, 2013, 12:24 PM
mchutch's Avatar
If it's once a year, I could open it, but it won't be easy to reassemble.
Since I have nickel plating, what do I use to clean it?
If it will come clean by opening it and cleaning it by hand, I will do it..
Old March 12, 2013, 02:04 PM
mchutch's Avatar
Well the plexi cleaned with soap and water, now to figure out what to use on the nickel plating.
Everything will be rinsed thoroughly with distilled water at the end.
Old March 12, 2013, 02:58 PM
turtletrax's Avatar
Ketchup works well to clean copper and nickel. (citric acid)
Just remember to align the o-ring properly when fitting the top and finger tight all the screws then tighten in a star fashion. No need to over-tighten the screws either. You will feel the screw seat itself and the o-ring will compress to fill the void and it will be sealed fine.
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
BBQ Cleaning!! rjbarker Off Topic 10 December 23, 2012 08:09 PM
Cleaning Help! Masteroderus Troubleshooting 5 July 21, 2012 01:33 PM
Cleaning Ram. shammancer RAM 10 January 11, 2012 08:28 AM
Cleaning a Rad miggs78 Water Cooling 2 March 20, 2010 09:29 AM
cleaning your LCD mo' power Display Units 20 January 17, 2009 08:32 AM
