  #21 (permalink)
Old March 14, 2013, 07:16 PM
Mark's Avatar
I just picked up a chunk of 3/8 tubing, cut enough to cover the barbs..added some super glue ( for rubber, plastic ) on top of the tubing then put the 1/2" on top of it with a clamp...it will work.
CHEERS
  #22 (permalink)
Old March 14, 2013, 07:22 PM
KaptCrunch's Avatar
was the superglue touching fluid ? using a a filler ?
and use gear clamp
  #23 (permalink)
Old March 14, 2013, 07:27 PM
Mark's Avatar
and use gear clamp
Yup gear clamps are the best. The glue is not touching any fluid. It's a water tight adhesive superglue that will bond the 3/8 to the 1/2" and the clamp will be tightened after the glue area to crimp the tubes for a tight fit and to prevent less water resistance ( which I think is completely overrated concerns for water cooling as is the choice of which way the loop should run - personally, less length, less adapters = less mess )
CHEERS
  #24 (permalink)
Old March 14, 2013, 07:39 PM
lowfat's Avatar
Not sure about you, but I sure wouldn't want to risk all that hardware to superglue. Honestly I would just not use the block, it won't help the overclocks or anything like that.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #25 (permalink)
Old March 14, 2013, 09:55 PM
KaptCrunch's Avatar
agreed for seen rez's that were glued leaked after time
  #26 (permalink)
Old March 15, 2013, 05:22 AM
Hooded's Avatar
I don't know why you wouldn't just buy a couple 3/8 fitting from Daz and use them to run a tube to and from the VRM heatsink.
I wouldn't be using any super glued in one of my systems. I wouldn't sleep at night.
  #27 (permalink)
Old March 15, 2013, 07:09 AM
Mark's Avatar
It's not glued to the barb. The 3/8 tubing is placed on the bard, then a little super glue for rubber is applied on top, then the 1/2 on top ( very tight fit ) then clamp. There's no way it will leak but I will test it. I did this before with my previous Asus mb and never had an issue. The trick is to use good clamps ( not those cheap plastic clamps ) and clamp near the end of the barb.
It will be fine
CHEERS
  #28 (permalink)
Old March 15, 2013, 11:39 AM
WhippWhapp's Avatar
Manifold, parallel loops.
I rub and whack and choke and stroke!
  #29 (permalink)
Old March 15, 2013, 12:04 PM
KaptCrunch's Avatar
home depot but need 3/4 hose or macgavier
  #30 (permalink)
Old March 15, 2013, 02:22 PM
WhippWhapp's Avatar
This is what I had in mind.
[WTB] 3/8" Barbs & 5/8" Clamps (Need ASAP) Insomnia9669 Buy/Sell & Trade 6 November 2, 2012 03:52 AM
[WTB] 1/2" ID 3/4" OD fittings/barbs asap, vancouver area Mekaw Buy/Sell & Trade 2 February 12, 2011 10:16 AM
[WTB] G1/4 1/4" Dia. barbs WolfBane Buy/Sell & Trade 12 September 18, 2009 08:31 PM
[WTB] 1/4 barbs for watercooling (1/2" ID) Toronto122 Buy/Sell & Trade 5 February 24, 2009 05:48 PM
WTB: 2 x Thermochill 1/2" barbs ASAP! Apollo4g Buy/Sell & Trade 9 September 17, 2008 05:22 AM
