Old March 4, 2013, 06:34 PM
yycraven's Avatar
Default Radiator
Hey everyone
Just wondering which would be best going to build a new set up and thinking of water cooling
Looking at these Rads XSPC RX360
Performance Triple 120mm Radiator XSPC RX360
or
EK-CoolStream RAD XT 360 - Triple Standard 120mm Radiator
as well same site but its a EX360
they all seem same, except for the fatter one.
Just wondering any advise would be great.
Thanks guys!
Old March 4, 2013, 06:46 PM
Bloodystumps's Avatar
The RX is good but I think you will need higher pressure fans the EX360 is a good performer and doesn't need high pressure fans (the EX360 would be my choice) and the EK you can throw that in the garbage..
Old March 4, 2013, 07:00 PM
lootbag's Avatar
If you can fit the RX360 and be able to run push & pull fans, it will offer better heat dissipation.
Old March 4, 2013, 07:26 PM
yycraven's Avatar
I will have to think of getting a different case then what I was going to use is CM 912 or CM 690.
Well now have to decided on either RX or EX
Old March 4, 2013, 10:16 PM
lowfat's Avatar
They will perform within a degree or two of each other. I'd grab the EK just because it is cheaper.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 4, 2013, 10:27 PM
I would go with the EX360 @ NCIX Because it is cheaper and performs well..
Old March 4, 2013, 11:40 PM
dustin1706's Avatar
The RX360 is one of the best rads for low rpm fans at 60mm thick and 8 fpi. The EK is 47mm and 11 fpi. The EX is 35mm and 20 FPI.
In a nutshell, the EK is similar to the RX, but performs a little worse than the RX as it uses brass tubes with copper fins. The EX is much thinner with higher FPI, so it will require more static pressure and air volume to provide equivalent cooling to the RX. The EX also uses brass tubes. The RX uses copper tubes and fins.
If room is a concern, go with the thinner EX with faster fans. If you have the room, or if silence is a concern I'd definitely go with the RX and some quiet fans. Price difference is only $25 between RX360 and EX360 at dazmode.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old March 5, 2013, 10:12 PM
yycraven's Avatar
Thanks guys for your input, just ordered the EX360 from dazmode.
Need someone who has a 120.2 Radiator AmuseMe Off Topic 0 August 13, 2012 06:34 PM
Should I add another radiator or will it be enough? siegfx Water Cooling 18 February 8, 2012 08:56 PM
Is one radiator enough oksir Water Cooling 12 March 25, 2011 12:48 AM
Fan for radiator phil3_66666 Water Cooling 9 April 21, 2009 02:44 PM
Radiator? nick_black Water Cooling 8 February 12, 2008 08:24 PM
