Old March 2, 2013, 12:21 PM
G777's Avatar
Default Primochill sysprep: Worth trying?
Hey all, planning on redoing the tubing in my loop and purchased 10' of primochill's advanced LRT tubing.
To my surprise it came with a small bottle of something called 'sysprep', intended to be used to help clean your loop while flushing.
Anyone here have any experience with this product they'd like to share?
Thanks!
Old March 2, 2013, 12:47 PM
Lpfan4ever's Avatar
I didn't use mine, I don't really even know what it is. All I can say is watch your bends really carefully with that tubing. Mine collapsed in two weeks with a very minor curve to it.
Originally Posted by encorp
Code:
<firebane> slightly used
Old March 2, 2013, 01:23 PM
JD JD is offline
Maybe it collapsed because you didn't use the sysprep?
Old March 2, 2013, 01:33 PM
yycraven's Avatar
I hope this helps.
PC-SPREP
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old March 2, 2013, 02:53 PM
KaptCrunch's Avatar
lol shelf life 2 years bet isn't any dates on the bottle
Old March 2, 2013, 02:54 PM
KaptCrunch's Avatar
shock load the loop to remove plaasticizers
Old March 2, 2013, 06:04 PM
G777's Avatar
Actually there is, I know the pic is fuzzy but the third line from the bottom says Run Date 12/04/12.
Old March 2, 2013, 09:34 PM
sourthings's Avatar
Really ? Man, that sounds not good at all for tubing to fold in like that so quickly...
3930K. RIVE, 16GB DDR3, Titan SLI
Old March 2, 2013, 09:48 PM
Lpfan4ever's Avatar
Hardy har har Everything had just been flushed out about a month before I got that tubing, so I didn't wanna go through that hassle.
It's entirely possible I got a bad batch, or it was just that section of tubing. So far the rest of it in my loop is alright, but I'm still not planning to go with Primochill for my next purchase.
Code:
Old March 3, 2013, 01:13 AM
Rollergold's Avatar
Never used the sysprep . I'm no fan of the Advanced LRT tubing at least in the 5/8 OD 3/8 ID size however. Had to dip the tubing in boiling water for over 5 min to even think about getting that stuff over the barbs on my Swiftech Lok-Seal compression fittings. Getting the compression collar screwed down; HA that was 100% impossible to even get the collar's own threads to start connecting with the threads on the barb using my hands, LET ALONE actually getting the collar screwed down. Maybe I too got a bad batch but I'm not impressed with the advanced LRT tubing
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
Primochill vs Masterkleer ~4months use kazenagi Water Cooling 7 January 20, 2012 02:00 AM
Primochill Typhoon IV tehpr0fess0r Rumor Mill 30 January 18, 2012 09:51 AM
Primochill ICE and silver coil...ok to mix? peter.t Water Cooling 1 April 13, 2010 09:41 PM
Sysprep Questions Chos3n O/S's, Drivers & General Software 3 June 18, 2009 12:40 PM
Primochill Ghost Fittings JD Water Cooling 2 August 8, 2008 08:40 PM
