Originally Posted by Reaper2794 As long as you know what you're doing, it would make more sense to get the reservoir separate right? I don't care to "play it safe", I'll be reading up to make sure I do everything right. |
Actually if there is any chance you may wish to use the res connected directly to the pump your better to go with the kit that comes with the
pump top and stand. You can purchase a seperate
res bottom cap for $10 if you wish to go with the res fittings setup insted. You can't buy the parts for the pump top seperately.
Most backplates have more screws than just the 4 GPU heatsink screws The one on my 6970 has about 10 that are spaced across the cards lenght. The backplate is harder and thicker than the PCB so it's giving it support from bending or warping from the weight of the block.
Rads will either list the fin count/inch or say low density or high density
