Old March 13, 2013, 02:49 PM
Killswitch's Avatar
Originally Posted by mchutch View Post
I would pay you to build a rig for me, I can see a lot of effort on this beauty.
I guess worse case scenario, external mounted rear 240 rad?
Thanks!!
I thought about an externally mounted rad off the back but I know I won't like how it'll look.
Old March 13, 2013, 08:59 PM
You can cause a substantial drop in pressure by running parallel path of least resistance and all that jazz zero flow control other than depending both blocks to pressure up exactly the same. If you were to run a heating or cooling system in a house like that it wouldn't perform at all without some controls in place. It's almost always better to run in a series and it's cheaper too. I run both my 6970's in series loop and I have never seen the lower card higher than a degree over the 1st card in the loop.
To figure out what is needed for rads you simply need to know what your max thermal heat load is and your max thermal dissapation via the rads your using. The rule of thumb is ONE 120 rad w/ one fan for each water block.
it looks like your bottom rad is pretty huge.
Mah Rig now
Mah Rig before
My stuff for sale.
adding a second gpu Jaydu Water Cooling 7 December 17, 2011 05:42 PM
Adding More Ram. Charmster RAM 7 September 6, 2011 04:03 PM
Adding another SSD to my rig Mayoo Storage 5 June 22, 2011 05:24 AM
Thinking about adding a 5870 to my 5850, need some advice.... divertiti Video Cards 4 April 24, 2011 07:46 PM
adding a sig tag for F@H? Putz HardwareCanucks F@H Team 4 September 15, 2009 12:04 PM
