  #21 (permalink)
Old March 4, 2013, 02:40 PM
BeyondNight's Avatar
AP-15's are good, but for the same price you could get an Akasa Apache which is a PWM and quite a bit quieter, although your temps will go up by 1-2c
And just to mix things up another choice could be Aerocool sharks, they are pretty damn good at what the do aswell.
  #22 (permalink)
Old March 4, 2013, 05:22 PM
Originally Posted by Squeetard View Post
Here's a thought. A high static pressure fan does no good on the pull side in a push pull configuration. Better off with a high cfm fan on the pull side I think.
won't be doing push+pull.... i was going to put them in pull only because i've been told it doens't make any difference between push and pull and pull is easier to clean dust from :)
  #23 (permalink)
Old March 4, 2013, 06:03 PM
It doesn't really make a difference, maybe 1-2c.
Remember if a fan has high static pressure, meaning the air blowing out of the fan has a High/Positive pressure, then the air on the other side of the fan will have low/negative pressure.
High pressure and Low pressure always try to balance each other out, so the air being drawn in should have roughly the same CFM and static pressure as whats coming out the other end.
Its basically the same principle a Vacuum works on, just hope i explained it properly and don't sound like an idiot
  #24 (permalink)
Old March 5, 2013, 07:23 PM
mchutch's Avatar
Default fans
I love these ones, 25mm depth, as good as 38mm depth fans..
XSPC RASA RAYSTORM KIT SLEEVED FAN - 1650RPM 63CFM 29 dBa
[FS] Watercooling parts, fans, bunch of other junk.. kazenagi Buy/Sell & Trade 76 March 29, 2012 11:15 AM
NEW REVIEW: Fans speed influence on watercooling loop performance Dazmode Water Cooling 10 April 23, 2010 08:14 PM
how long to run system ( watercooling) testing? Shadowmeph Water Cooling 27 July 13, 2009 06:04 PM
[WTB] Watercooling system DavidDemise Buy/Sell & Trade 4 June 7, 2009 08:27 PM
