  #21 (permalink)
Old February 23, 2013, 03:32 PM
Or just start with the basics.. if you change something and can't boot, make sure everything is connected properly. If it still doesn't work, revert the change. If it still doesn't work it's time to start ripping hair out :P
  #22 (permalink)
Old February 23, 2013, 05:27 PM
Bloodystumps's Avatar
Good job you figured it out man
I've got the same setup so if you need anything just ask
  #23 (permalink)
Old February 23, 2013, 11:00 PM
Jeff1961's Avatar
Things went well with the bios and many hours were spent playing with the cooler software. (CorsairLink 2, ver 1.0.5)
I uploaded a bit of the "adventure" to YouTube:
Corsair H100i Adventure - YouTube
...and yes, my nose was in the mobo manual often.
  #24 (permalink)
Old March 3, 2013, 05:28 AM
nasrott's Avatar
next time u run into this one stick of ram is all that is needed to boot, rest keep to the side for later, re-seat ram the one stick and your vid card, then restart, the more things that are involved, more chance something goes wrong. Keep it simple till ya get it up and going, is usually just something simple/stupid on our end. Good to hear ya got it worked out.
Tags
crosshair iv extreme , eyefinity , h100i
Corsair H80i & H100i Review Comment Thread SKYMTL Water Cooling 27 February 24, 2013 07:22 PM
Has anyone put an H100i in an older Thermaltake armor? Jim Johnstone Water Cooling 2 January 14, 2013 07:20 PM
Corsair H100i mini review stoanee Member Reviews 13 November 20, 2012 06:52 AM
Updating BIOS on GA-EP45-DS3L failed, how to access back up BIOS? Kayen Troubleshooting 5 August 7, 2008 06:31 PM
