"pull the battery"...this will change my bios back to the defaults correct? I'm not sure what that will require me to do if it brings back the bios.
Correct. It won't "require" you to do anything. But when it boots you may have to enable/disable onbaord sound and enable/disable AHCI as the case may be depending on how your system is set up.
You may want to try re-seating items before resetting the BIOS. That sure sounds like you have knocked the 12v connector loose. The 24pin one. Some of them can be finicky. You made sure it is fully seated and the clip engaged OK? I knocked mine loose and had all voltage LED go orange on me after upgrading my GPU. Scared the crap outta me. But it was as easy as ensuring the supply line was seated properly.
