Old February 20, 2013, 04:59 PM
Default Help a Watercooling nooby :3?
Hello all. So I've never done WC, but I have a big project coming up that I'm hoping to have done by the end of this year.
I have been doing some research, but I still got a lot to learn.
I have quite a few questions.
1) What tubing is usually recommended? I believe 3/8 and 1/4 are the most common? What is the pros and cons to each? I know the bigger tubing obviously cools more, but may look bulkier, and the bigger tubing also kinks easier..? Any other pros / cons?
2) What kinda fittings are there? Compression and barbed..? What are the differences, how do they work? I want to go for Matte Black Bitspower fittings as the color on them is just astonishing.
3) I want to get a cooling block for my upcoming 680, but I want a clear block, or a real nice black one. I've seen em on some cards, but can't seem to find the one I'm looking for. I want the blue coolant I'll be using (will be using Mayhem's Deep Blue dye) to show around the card. EX - http://www.murderbox.eu/_mdpc-murder...box-mk2-05.jpg
4) How do I know if a pump is powerful enough for my loop? Are there different kind of pumps?
5) How can I get a UV effect on my loop without the thing giving it the effect showing? I want a really clean build. I want to go for clear tubing so my colored coolant will show.
6) What are some popular reservoirs? I've only seen block kinda ones, cylinders, and the helix DNA looking ones. Isn't there more variety?
7) I'm in the US. What is popular other than Koolance, EKWB, XSPC, Bitspower? I feel like EKWB makes great quality blocks, whereas Bitspower has sweet fittings.
Thanks for your time guys. I have so many questions. I'm all over the place haha.
Old February 20, 2013, 05:30 PM
Bloodystumps's Avatar
1/2, 7/16 and 3/8 in that order are most common, common users won't notice the difference in performance..
Most use compression fittings but its all up to your taste, how do you want it to look??
unless your running an extreme loop most pumps will do just fine .
EKWB makes crap and not just with the recent run of plating, I wouldn't recommend any of their products......
if your in the US take a look at PCperformance, FrozenCPU , Aquatuning those stores will have a good supply to mull over .
Old February 20, 2013, 05:44 PM
ZZLEE's Avatar
Tube size
Larger flows easier and faster with less pressure.
look at area of circle vs radius. Volume off a tube vs Radius.
larger tube has less effect due wall friction on flow.
Primochill Primo Flex 1/2" inner 3/4" outer is what I have.
Rad have 1/2" G1/4 threads most of the time.
I was not as careful as should have been in my first water cooling.
Soon I Will try again
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 20, 2013, 07:28 PM
dustin1706's Avatar
Hey Reaper.
1) The most common sizes for tubing are 1/2"id 3/4"od and 3/8"id 5/8"id. The difference in flow loss is negligible, so just go with the look that you prefer. Some cheaper tubing is more prone to kinking on sharp bends than others. I like primochill 1/2"-3/4" myself.
2) For fittings, barbed fittings with hose clamps are cheaper, compression fittings are better looking but more expensive. Compression fittings have an outer collar that "pinches" the tubing to seal it to the fitting. Some people like to use undersized tubing on barbed fittings with no clamps, but I would not recommend this for someone new to WC.
3) When buying a waterblock make sure the block will fit the card. If you have a reference card, you need a reference block. If you are buying a non reference card, first make sure that there is a block available for it. Not sure exactly which block you are looking for, but EK makes a nice looking acrylic block for the 680 EK-FC680 GTX+ - Nickel - GeForce GTX 6x0 Series - Full Cover for Nvidia GeForce - VGA Blocks - Blocks
4) Yes there are several different pumps available. Two types of pump are very common: Firstly, the Laing D5 (aka MCP655) this pump comes in a fixed speed and variable speed model and has been rebranded by several retailers. Several aftermarket tops and reservoirs are available for it. Secondly, the Laing DDC. This pump comes in many configurations like the MCP350, 355 and 35x. Several retailers have rebranded these pumps as well, so you will see them with different names. There are lots of aftermarket tops and reservoirs available for these pumps as well.
In a nutshell, any of these pumps will be fine for anything but the most extreme WC setups. The "which is better" topic comes up all the time and there isn't a single right answer. From my experience and research: Positives of the D5 are that it is quieter, more reliable and pushes more volume at low restriction. Positives of the DDC pumps are that it is smaller, has more tops available, comes in PWM variations and pushes more volume with higher restriction. I personally use the variable speed D5 because it is quiet and reliable.
5) You can get leds or cathode lights. Cheaper leds are very directional while cathodes give off 360* light and are generally easier to position. To hide the UV lights just put them on the sides, top and bottom of the case up against the side with the window. This way they will throw the light into the case but will not be visible through the window.
6) Tons of reservoirs are available. Most commonly cylinder, integrated with radiator, square or 5.25" bay mounted. Some setups integrate the pump with the reservoir. Looking for something specific?
7) Those are some of the big names, but check out some retailer websites to see what else is out there.
Performance-PCs.com, ... sleeve it and they will come
Computer Liquid Cooling & Premium Air Products, Parts, Kits & Accessories | Sidewinder Computers
FrozenCPU.com | 1.877.243.8266 | World's Largest Selection of PC Modification Supplies
Jab-tech
www.dtekcustoms.com
Directron-Best Discount Computer Super Store-CPU Computer Parts Cases PC Hardware Software Power Supply Houston Motherboards Hard Drives Network Memory Repair Used Texas Compare Lowest Prices Cheapest Reviews Guide
Petra's Tech Shop
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old February 21, 2013, 06:59 PM
Ok yeah, I definitely want compression fittings
What's wrong with EKWB? Looks like the most advanced in terms of their design/marketing, obviously I don't know bout the quality of their stuff but I don't want biased answers.
Originally Posted by ZZLEE View Post
Tube size
Anywhere where I can compare tubing sizes? I wanna see good examples of how the sizes look so I can decide.
What are the popular tubing kinds/brands?
Originally Posted by dustin1706 View Post
Hey Reaper.
Jab-tech
www.dtekcustoms.com
Petra's Tech Shop
Is the outer collar the flat screw kinda lookin thing? Has a flat line in the middle?
Will that 680 block show the liquid? Why does EKWB have circles all over their stuff?
What do rebrands offer? How is one rebrand better than another? Pumps all look ugly, are they all just plain and simple and ugly like that or what?
What do I have to look for in looking for a reservoir?
Old February 21, 2013, 09:53 PM
dustin1706's Avatar
Here is a video of a creepy looking dude demonstrating how compression fittings work. Compression Fittings and how to use them - YouTube
EK stuff is actually really good quality. Unfortunately their current designs have circles all over the place, but they are now moving away from that. Back in 2011 they had some issues with the nickle plating on their blocks, but they were really good about RMAing any defective blocks. EK Official Statement for Nickel Plating Issues | EKWaterBlocks
Here is a video comparing 3/8 and 1/2" tubing from Dazmode. How to select tubing for your watercooling setup? Review and tutorial. - YouTube
No difference between the "brands" of pumps. Usually it's just a different sticker. Yeah, they are all pretty plain, but there are other "tops" or reservoirs that integrate the pumps.
D5 Dual Bay Reservoir/Pump Combo | XSPC
Bitspower 80mm Water Tank Z-Multi 803GP - Dual G1/4" Model (POM Version) Products Model: BP-WTZM-803GP-BK [BP-WTZM-803GP-BK] : Performance-PCs.com, ... sleeve it and they will come
Bitspower D5 / MCP655 Mod Kit - Red Finish Products Model: BP-D5MA-RD [BP-D5MA-RD] : Performance-PCs.com, ... sleeve it and they will come
A reservoir is a reservoir. Just a place to store some extra fluid. If you plan on using a reservoir that integrates a pump, make sure they are compatible. Otherwise, just go for looks. A few examples:
https://frozenqshop.com/index.php/pr.../novacore.html
https://frozenqshop.com/index.php/rcx160.html
https://frozenqshop.com/index.php/bayres.html
FrozenQ PC Mods Blue Meteor Light Limited Edition Reservoir - Blue Warp Drive Products Model: FQPC-WARPDRIVE-BL [FQPC-WARPDRIVE-BL] : Performance-PCs.com, ... sleeve it and they will come
Alphacool - CPU Kühlung und Wasserkühlung sowie PC-Cooling und Silent-PC Artikel von Alphacool - Alphacool Repack-cooling Slot-In Black 15609
EK-BAY SPIN Reservoir - Plexi CSQ - Reservoirs - Reservoirs & Accessories
EK-RES X3 150 - Reservoirs - Reservoirs & Accessories
Again, make sure your card and block are compatible. Not every 680 block and 680 card are the same. The block I linked is frosted acrylic, here is a pic from EKs website.
Old February 22, 2013, 01:52 AM
ZZLEE's Avatar
Candy store
*** Bundymania Watercooling Parts & Systems Picture Thread ***
He is Euro guy guy who reviews water cooling stuff.
Old February 22, 2013, 02:56 PM
You'll definitely want a top for your water pump, a D5 / 655 is a good strong pump and very reliable..
I have seen EK stuff that was poorly designed and shorted out GFX cards and then of course the nickle plating...... but regardless of quality it was the response to the nickle plating and attitude of the company that has me turned off and now the whole bubble wrap look to every piece they sell makes it even less appealing..
Old February 22, 2013, 03:44 PM
Prolab's Avatar
Start here:
Beginner's Guide to Water Cooling Your PC *** READ THIS FIRST *** - Overclockers Forums
And other guides you can find.
Having the knowledge on how WC works, WC parts, delta T, what to expect, etc will be beneficial to your project. Helps you avoid the common mistake most noob WC'ers.
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, AMD BE 1100T OC to 4.07 ghz, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Crosshair V, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (4) 2 TB WD Green Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (2) 2 TB WD Green, (2) 2 TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
watercooling help shaznuts Water Cooling 4 April 25, 2011 12:40 AM
quick nooby question Cadence Power Supplies 8 December 29, 2008 11:35 AM
Is WaterCooling for me? arekieh Water Cooling 10 October 20, 2008 05:50 PM
Watercooling P5e Phobia Water Cooling 4 June 20, 2008 08:30 PM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
