  #41 (permalink)
Old April 18, 2013, 11:26 PM
Originally Posted by bigFOIG View Post
Depends on the waterblock I guess. Everytime I've watercooled a GPU, it's turned a 2 slot card into a single slot card. So that means it got thinner. But looking at the waterblock above, that thing looks huge.
Really now? Now this is even more intriguing... I might just get a generic block then :)
So pretty much the only setback with generic blocks is that I'll have to do some manual placements of certain things - IE: that copper plate, and those black heatsinks?
  #42 (permalink)
Old April 19, 2013, 05:16 AM
KaptCrunch's Avatar
the copper for gpu to rise WB off the PCB and the black for ram, vr's
if handy like DTI with die grinder keep the fan housing and ram heatsink intact just cut out Gpu area for WB to fit ...may have to use a thicker copper spacer
DTI: i'd keep the fullcover and drill hole where R22 touching and make a new heatsink for the vr's there is no water going to them
  #43 (permalink)
Old April 19, 2013, 04:16 PM
DTI DTI is offline
That might of worked with the XFX card, I exchanged it for the Gigabyte 7970 ghz the Gigabyte has a separate heat sink for the vrs and what the hell does vrs stand for
And there is no way that full block will work with this card, If I have time tonight I will install it although it should be funny what it will look like after.. bring back to those old 9800 pro days heat sinks and fans everywhere
  #44 (permalink)
Old April 21, 2013, 02:26 PM
DTI DTI is offline
Did another bonehead move those black heatsinks that I ordered all 24 of them way to big cant believe myself some times get online and start buying the aluminum small one is what I should of ordered, installed the vga block last night played some games temp doesn't go past 40c
  #45 (permalink)
Old April 21, 2013, 10:38 PM
ah the joys of ordering shit online... yeh i'm out 50 bux on the last order too. I thought the EK backplate would work with my card... nope one hole is off by 2mm.
BAH RAWR RAWR! Glad to see you got your vid under water finally. There goes the most annoying noise a gaming computer makes.
Mah Rig now
Mah Rig before
My stuff for sale.
  #46 (permalink)
Old April 22, 2013, 12:00 AM
Oh wow! That doesn't like that difficult at all!
So what are those (pardon my idiocy) black heatsinks for? Doesn't seem that you are using them?
  #47 (permalink)
Old April 22, 2013, 03:56 PM
DTI DTI is offline
The black heatsinks are to be mounted on the video card memory they have a peel and stick thermal tape
I did the old order now and check later plan so the heatsinks are the wrong size and its not hard at all to install but can be a bit of hassle with the coolant
  #48 (permalink)
Old April 22, 2013, 04:39 PM
KaptCrunch's Avatar
the VR's are the voltage regulators
you should use heat sinks on your ram chips
  #49 (permalink)
Old April 22, 2013, 05:07 PM
sswilson's Avatar
They're easy enough to cut down to size using a dremel tool. Been there, done that, although these days of cool(ish) chipsets, vid cards are really about the only legit use unless a person was doing some form of extreme OC'ing with ultra high voltage suicide runs.
  #50 (permalink)
Old April 23, 2013, 08:20 PM
DTI DTI is offline
That's a good Idea with the copper plate and stick the heatsinks to it
I ordered these from Dazmode I hope they are right Black Performance RAM Heatsink 14x14x10mm
[FS] XFX 7970 $300 severity Buy/Sell & Trade 72 October 14, 2012 08:21 PM
[FS] 7970 + EK waterblock+EK backplate+1 slot I/O bracket, Antec HCP-1200 Levesque Buy/Sell & Trade 3 October 1, 2012 11:49 AM
Waterblock for my Gigabyte 7970 OC Mnemonicman Water Cooling 15 September 20, 2012 07:15 AM
[FS] FS: **SOLD** 7970 + EK waterblock + EK backplate + 1 slot I/O bracket Levesque Buy/Sell & Trade 16 August 17, 2012 06:34 PM
EK 7970 lightning waterblock NiteOwl Water Cooling 8 August 2, 2012 01:51 PM
