  #31 (permalink)
Old March 21, 2013, 12:06 AM
Astaroth's Avatar
You will need a watertight seal which also entails a proper O-ring to accomodate whatever modfications you make. Unless you can work modding miracles on that block, cut your losses and buy a universal block and some copper heatsinks. Call it a day.
  #32 (permalink)
Old March 23, 2013, 03:21 PM
Trial Member
A stupid question:
do you have THICKER heat conduction pads for the back copper part?
If the R22 things are too high and the back copper part do not made contact with the voltage regulators, simple put a thicker pad on it.
What about the other parts that need cooling to?
Are these covered and cooled with the waterblock?
If all other parts are covered and cooled, and only the voltage regulators behind the R22 things are not covered and cooled, put a thicker pad on it.
Sorry for my English.
I have the same stupid problem with my new XFX card and EK Waterblock CSC Nickel.
  #33 (permalink)
Old March 23, 2013, 06:52 PM
Hate XFX, used to like em cause their nice PSUs, but their video cards are a goddamn joke.
  #34 (permalink)
Old April 16, 2013, 04:11 PM
Universal blocks? Ooo? I'm currently in this exact same situation, except I haven't purchased a block yet and I'm slightly new to the whole watercooling gig.
Does it require any abnormal tools to use a universal block and copper heatsinks?
  #35 (permalink)
Old April 16, 2013, 04:36 PM
If you're using a universal block with a 7950/7970 then you'll need this: EK-VGA Supreme HF HD7970 Cu Adapter.
Universal GPU Block
RAM + VRM heatsinks
Copper shim (if it's a 7900 card)
RFD Trader Feedback
  #36 (permalink)
Old April 16, 2013, 05:33 PM
This card is reference just incase you are wondering.
HIS Radeon HD 7970 3GB GDDR5 PCI-E w/ DVI, HDMI, Dual DP at Memory Express
Notice the single dvi port...
My stuff for sale.
Mah Rig
  #37 (permalink)
Old April 16, 2013, 07:06 PM
DTI DTI is offline
Universal GPU Block
RAM + VRM heatsinks
Thats the piece I forgot but have it now
just trying to get motivated to install it
  #38 (permalink)
Old April 16, 2013, 11:16 PM
Wow that all looks very foreign to me.
I see where that Copper plate should go though.
As far as getting all these peices, how much of a dent in my wallet will it make?
I currently have another 7970 coming in (I have 2, I'm selling one and I plan on watercooling the other) which is the reference model.
This new 7970 I can just buy the regular waterblock, but for my other "newer" card, I believe I will have to do all this tomfoolery with it.
Question: Does adding a waterblock to the card change the thickness of the card much? Does it make it noticeably thicker than with the original heatsink+fan on it?
I'm not tight on space, but still would like to know.
Thanks a bunch guys!
  #39 (permalink)
Old April 17, 2013, 05:48 PM
should start another thread for your questions mang. Just sayin...
My stuff for sale.
Mah Rig
  #40 (permalink)
Old April 18, 2013, 03:42 PM
bigFOIG's Avatar
Depends on the waterblock I guess. Everytime I've watercooled a GPU, it's turned a 2 slot card into a single slot card. So that means it got thinner. But looking at the waterblock above, that thing looks huge.
[FS] XFX 7970 $300 severity Buy/Sell & Trade 72 October 14, 2012 08:21 PM
[FS] 7970 + EK waterblock+EK backplate+1 slot I/O bracket, Antec HCP-1200 Levesque Buy/Sell & Trade 3 October 1, 2012 11:49 AM
Waterblock for my Gigabyte 7970 OC Mnemonicman Water Cooling 15 September 20, 2012 07:15 AM
[FS] FS: **SOLD** 7970 + EK waterblock + EK backplate + 1 slot I/O bracket Levesque Buy/Sell & Trade 16 August 17, 2012 06:34 PM
EK 7970 lightning waterblock NiteOwl Water Cooling 8 August 2, 2012 01:51 PM
