-   -   Fans for H100 (where to get etc..) (http://www.hardwarecanucks.com/forum/water-cooling/59687-fans-h100-where-get-etc.html)
trayton February 14, 2013 08:52 AM
Sorry if this is the wrong forum feel free to move mods!
I'm curious what are the best fans to get (4 fan setup or 2 for now depending on price) for a H100 (not the new H100i).
I prefer to do 2 fans on each side (I believe its called the Push/Pull?)
Curious what fans you guys recommend and where to purchase from.
Thanks in advance. Also the H100 is on sale for $79.99 I do believe at CC do you guys think thats a decent price? Debating if I should get another one lol!
great_big_abyss February 14, 2013 08:58 AM
Corsair SP120 2-pack
Alpine February 14, 2013 09:32 AM
for my H100, I have buy 2 Scythe Gentle Typhoon 120MM Japan Servo Double Ball Bearing 1850RPM Case Fan. They are very quiet.
I got them for 20$ for both on special
NCIX 2 Pack Bundle Deal Scythe Gentle Typhoon 120MM Japan Servo Double Ball Bearing 1850RPM Case Fan
Soultribunal February 14, 2013 09:52 AM
Moved to Watercooling section,
-ST
Adzsask February 14, 2013 09:59 AM
Gentle typhoons for push/pull, maybe some 38mm thick sanyo denki's if your using only 2 fans. I use GT's on every build that requires 120mm fans myself.
stoanee February 14, 2013 10:00 AM
The GT 1850's are still my favorite, better than the Corsairs IMHO (I own both)
trayton February 14, 2013 10:24 AM
Where would you recommend getting the GT's I will checkout the other links as well guys and thanks for input :)
EDIT : OOps think that is the link above do they ever get cheaper or anywhere cheaper to get them from...
Also Soul - Thanks for moving to appropriate section :)
lootbag February 14, 2013 01:47 PM
NCIX sometimes has the GT AP-15s @ $24.99 for (2) during their weekly sales.
Other than that, I have not really seen them at a lower price.
I used AP-15s with my radiators but the Corsair SP120 Quiet Editions do look nice, been wanting to try them.
rfglass February 14, 2013 04:07 PM
I use these, got them on sale for $10 each awhile back.Newegg.ca - COUGAR CF-V12HP Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 12CM Silent Cooling Fan with Pulse Width Modulation
AkG February 14, 2013 04:26 PM
The cougars are 'meh'. Tried them, prefer Corsair SP's to them (the sound profile of the Cougars just gets on my nerves). Gentle Typhoon's are also excellent. Cant go wrong with either.
