Old February 14, 2013, 05:51 PM
ipaine's Avatar
I have both the Corsair SP120's and the Gentle Typhoons. I used the typhoons when I was just using 2 fans and now I'm using 4 SP120's. I would say they are both great fans. You can't go wrong with either option.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old February 15, 2013, 12:42 AM
Rollergold's Avatar
I would go with the GT 1850's (AP-15's) for the H100. The H100 fin density isn't particularly low @ 11-12 FPI so your better off with a higher RPM fan and the GT 1850 is amazingly quiet for a fan that spins at nearly 2000 rpm. I've never tried the "Quiet" SP-120's but the "High Performance" ones were much too loud for me. Also I'm not a fan of Push-Pull configs on fans, unless your going for the best overclocks, I don't feel its worth the extra bulk and the extra hassle when it comes time to clean the dust out of the rad. But for 79 dollars that's a steal of deal for the H100.
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
Old February 15, 2013, 03:25 PM
Guys..
Just curious but CanadaComputers really ticks me off as does Tiger Direct on how they do their pricematch (where its local only).
I'm curious does bestbuy sell the fan? I saw they have the same name but not quite the same model is their a huge difference because its free shipping over $20 and I need 4 fans.
Corsair Air Series AF12 120mm Computer Case Fan (CO-9050003-WW) : Computer Fans & Cooling - Best Buy Canada
Corsair Air Series SP120 120mm High Static Pressure Computer Case Fan (CO-9050007-WW) : Computer Fans & Cooling - Best Buy Canada
http://www.bestbuy.ca/en-CA/product/...72df634910en02
Corsair Air Series SP120 Quiet Edition High Static Pressure Computer Case Fan (CO-9050005-WW) : Computer Fans & Cooling - Best Buy Canada
Let me know asap if possible as I was going to pickup tonight lol long weekend and all!
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
Old February 15, 2013, 04:51 PM
clg clg is offline
Futureshop/bestbuy may have some decent computer items available, but it's usually online sales only. The items page tells you availability, and those fans are online only.
Ive got an h100 myself and I've noticed a pulsating hum that goes away when I disconnect the fans. WTFFFF?! I want to replace them but I've read I'll need to control them separately as the pump unit will only control the oem ones. Fact/fiction?
Old February 15, 2013, 05:38 PM
Ya i know its online only but curious which one of those fans are best as I'm not sure its the exact same one as the poster above said to get...
Old February 15, 2013, 05:55 PM
clg clg is offline
The AF series from Corsair are more so for intake/exhaust case fans, they're designed to have lots of clearance all around. The SP series is designed exactly for your application, pushing/pulling air through obstacles.
NCIX has the fans quite a bit cheaper too.
Old February 15, 2013, 05:59 PM
ya but if one of the ones listed above works (just need to know which model is best outta the 5 i listed), then i can order through BestBuy and pricematch :) also shipping is free over $20 lol and I'm spending $40 easily!
Old February 15, 2013, 06:11 PM
clg clg is offline
Go for it then and grab the SP's. Here's a comparison between the quiet edition and high performance, to me it's a no brainer to put up the extra noise but that's your call.
AnandTech - Choosing the Best 120mm Radiator Fan: Testing Eight Fans with Corsair's H80
  #19 (permalink)
Old February 18, 2013, 04:34 PM
Agree with others in thread. I really like the Gentle typhoons. Very quiet and push a lot of air when you need them to.
  #20 (permalink)
Old February 19, 2013, 10:28 PM
Bungwirez's Avatar
GT Fans... all your needs supported at Dazmode.
Scythe Gentle Typhoon 1850RPM 59CFM @ 28db Fan
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Replacement fans for a Corsair H100 Rollergold Water Cooling 9 November 30, 2012 02:58 AM
Fans needed for Corsair H100 Alpine Water Cooling 16 September 28, 2012 06:42 PM
Replacing CM Evo fans with Noctua NFP12 Fans kr7777 Air Cooling 7 August 26, 2012 10:51 AM
H100 trayton Water Cooling 19 March 5, 2012 12:55 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
