Old January 30, 2013, 03:03 PM
Liu Kang's Avatar
Nice to see Corsair continuing to improve this product. I have an H80 and couldn't be happier given the price point...
That being said, I wouldn't call it water cooling ;)
Thanks for the write up, AKG.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old January 30, 2013, 03:07 PM
Soullessone21's Avatar
Thanks for the write up, SKY.
SKY:O did you change you name :P
Give credit where credits due :P
Author:
AkG
Date: January 29, 2013
Product Name: H80i & H100i
Part Number: CW-9060009-WW / CW-9060008-WW
Warranty: 5 Years
Current Build:http://www.hardwarecanucks.com/forum...cube-gods.html
Always up for a Beer in Calgary or Area
“Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.”
Old January 30, 2013, 03:14 PM
Liu Kang's Avatar
Edited ;)
LK
Old January 30, 2013, 08:52 PM
Phill's Avatar
Originally Posted by stoanee View Post
I swapped out a NH-D14 for a H100i on my 3930K and it is worth every penny.
Really? Would you please further explain why it is worth every penny? You see I own two NH D14's and have been tempted to move to H100i or Swiftech H220.
Thank you
Old January 30, 2013, 09:05 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Thats easy. No more couple pounds of metal hanging off the mobo. All the CPU heat is exhausted OUT of the case - ignore Corsair's recommendation on air direction its....suboptimal. Easy control over the fan speed/noise profile. As good to better cooling potential. Ease of installation. Ease of swapping ram. Bragging rights. The list does go on and on. ;)
Old January 30, 2013, 09:18 PM
Phill's Avatar
I was hoping that I would hear that the h100i would out perform the D14 by a decent margin. 5C or more would be nice under load.
It would be nice to have a NH D14 or ___________ best air cooler vs the h100i/X60/H220 comparison. Personally I have not touched my D14 for a long long time. It is in my case and it keeps hot things cool. I use ASUS Fan Xpert to manage fan speeds.
Old January 30, 2013, 09:26 PM
AkG's Avatar
AkG AkG is offline
Then you will most likely want to look at the NZXT X60 (and maybe H110). Its even bigger and better. Should easily beat a D14. /whistle
Old January 30, 2013, 09:31 PM
Phill's Avatar
Linus ran the X60 through his test bench. It narrowly beat the H100i. I was not impressed. I expected more. :(
  #19 (permalink)
Old January 30, 2013, 09:46 PM
Phill's Avatar
It it okay to post this here? https://docs.google.com/spreadsheet/...GSFZNRmc#gid=0
  #20 (permalink)
Old January 30, 2013, 10:01 PM
AkG's Avatar
AkG AkG is offline
Lets just say that when you stick four good fans - like the stock NZXT fans- on a 280mm rad...its a beautiful thing. The H100i is a beast, but the X60 is a bigger beast. ;)
Corsair H100i mini review stoanee Member Reviews 13 November 20, 2012 06:52 AM
Comment Thread for Corsair HX620 PSU Review SKYMTL Power Supplies 25 September 29, 2009 05:49 AM
Corsair HX1000W Review Comment Thread SKYMTL Power Supplies 15 November 20, 2008 02:08 PM
Corsair TX750 PSU Review Comment Thread SKYMTL Power Supplies 22 March 25, 2008 02:02 PM
