-   -   Sketchy waterblock... (http://www.hardwarecanucks.com/forum/water-cooling/59408-sketchy-waterblock.html)
Trocko January 29, 2013 07:05 PM
Aliexpress.com : Buy GTX250 9800 8800 HD4870 HD4850 HD4860 GTX480 GTX470 GPU cards VGA water block from Reliable water block suppliers on E&P's store
So..... I have been searching for a swiftech mcw60 for a while now, because it has reallly frickin high flow rate, and its pretty cheap too (if you have the fortune of finding one that is) I found one in the GTA, but im in NS and the guy didnt want to ship (nbd). So i went on ali express and found this.. Its copper, but i dont even know what to think of it. Would it be restrictive, or would it blow my mind? Does anyone have exp with blocks like these?
If its bad, i might settle on a mcw82.
Hooded January 29, 2013 08:54 PM
Check this out.
https://www.dazmode.com/store/produc...erblock_-_oem/
Trocko January 29, 2013 09:46 PM
OMG, you are the best!! i didnt even check that... WOOOOOOOOOOOOOOOOOOOO
