Old January 27, 2013, 05:38 PM
Default Are these fittings any good?
ModMyToys Carbon Fiber Enhanced Compression Fittings, 1/2" x 3/4" Single - Matte Black Products Model: MMT-CFF-MB-BK-1234-1 [MMT-CFF-MB-BK-1234-1] : Performance-PCs.com, ... sleeve it and they will come
Seems pretty awesome but if the quality is terrible then not so much. Anybody used these or heard anything about them?
Old January 27, 2013, 07:22 PM
the copper versions were recently reviewed here
to summarize:
"While I may be an old-school barb and clamp user, and I have had some issues with other compression fittings, the monsoon free center design is really a step above the rest in terms of eliminating or reducing the common problems associated with most compression fittings. The problem of loosing your finger tips and never quite getting things as tight as you would like are gone, you now have a tool to do the work for you and you have a very sleek and smooth look that is unmatched. I’ve been generally very impressed with these monsoon compression fittings and suggest you give one or two a try before making a decision on what to build your system from. With fittings, I would always suggest trying one or two yourself first as you do kind of buy into a style and it’s worth making sure with one barb sample first. The monsoon compression fitting is the first to really change up and clean up the looks of compression fittings and they have also improved several areas of performance and improved the user experience while doing so. I recommend them very highly."
Old January 28, 2013, 04:17 AM
Alright cool, thanks!
Old February 18, 2013, 04:01 PM
I am a big fan of Bitspower compressions and fittings. I have yet to have a compression leak or even remotely pull apart. I have had such great success with BP fittings, I havent used any other brands.
Old February 20, 2013, 03:06 PM
Zer0's Avatar
I use Monsoon compressions in my ITX build (ModMyToys is PPCS's in-house brand that is manufactured by Monsoon). They work fine but I do prefer the more expensive Bitspower ones though. The wrench is a little finicky because the tubing rubs against it which makes it hard to turn.
Old February 23, 2013, 08:58 AM
Nice build Zer0. Simple and neat.
Old February 23, 2013, 10:53 AM
Zer0's Avatar
Thanks.
Old February 23, 2013, 11:13 AM
ZZLEE's Avatar
the tube cutter helps allot to stiaght cuts that make plumbing easier.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 23, 2013, 12:29 PM
Zer0's Avatar
Yea, I used to use a box cutter, what a b#$^@ that was lol. I could never get it perfectly straight.
[FS] Watercooling Fittings mmansueto Buy/Sell & Trade 10 May 3, 2012 04:59 AM
Heatkiller and Fittings MattC Water Cooling 13 July 21, 2011 10:28 AM
Need some advice on fittings jtarle Water Cooling 13 December 24, 2009 11:32 AM
Help Me Choose My Fittings Please. JORD4N Water Cooling 4 December 5, 2009 11:11 AM
[FS] WC fittings and other stuff... Frank Booth Buy/Sell & Trade 1 April 26, 2009 05:21 AM
