  #21 (permalink)
Old January 24, 2013, 10:35 PM
but since the fan is spinning at such a low speed, would it be enough static pressure to get thru the rad?
  #22 (permalink)
Old January 25, 2013, 08:36 AM
BigPhatPaulie's Avatar
those factory corsair 200mm fans are awful.... no real air flow to speak of..... thats why I put 2 120mm fans in the front of mine and 2 120's up top (with a rad of course)
FOR PONY..... that is alll
  #23 (permalink)
Old January 25, 2013, 09:51 AM
r0k0's Avatar
how did you make the 240 rad fit ?
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
  #24 (permalink)
Old January 25, 2013, 01:10 PM
lowfat's Avatar
The stock fans are only 20mm thick and have a tiny motor. These make the fan have very poor static pressure which is is rather important to a radiator. I would suggest moving to a thicker fan. IIRC you can use 180mm Silverstone fans w/ the 200mm Phobya. However I am not sure how you would go about mounting it to the case.
  #25 (permalink)
Old January 26, 2013, 07:50 AM
It's an xspc rad ( normal thickness) and my mobo doesn't have a vrm heat sink along the top so I mounted it inside the case and put the fans in the top of the case pulling air through. However I also cut out the mesh in top and just left the fan mount holes so that thenair flow wouldn't be disrupted. I would post pics but in just on my iPad ATM
  #26 (permalink)
Old January 27, 2013, 06:40 PM
i got shipments from dazmode within a day or so.
  #27 (permalink)
Old January 27, 2013, 06:46 PM
lowfat's Avatar
Just an FYI. Phobya announced an all copper version of their 200mm radiators today. No idea when it will be in stock in retailers though.
  #28 (permalink)
Old January 27, 2013, 07:28 PM
r0k0's Avatar
Oh so the 240 is on top ? I thought in the front lol i'll have to buy a 140 single rad or buy a nice new slim 240 rad and cut a small opening in the 5.25 and run the tubing in there cause when i get the 6990 inthere i will be needing lost of cooling help, also looking at those cougar fans
Since they might be releasing a 200 copper i might wait also and run the 6990 aircooled for the moment
Main Rig
Canadian Eh ?
  #29 (permalink)
Old February 10, 2013, 11:59 PM
Any update on this thread? Did OP end up buying at aquatuning? I am contemplating on purchasing the new Phobya Xtreme 200mm V2 from them. Thanks!
  #30 (permalink)
Old February 11, 2013, 06:18 PM
r0k0's Avatar
no, i've bought 6 cougar fans, so i will be putting a 240 rad and modding the 5.25 so i can pass my tubing from the inside the 5.25 bay
since i cant find a good 200mm fan to push that's why i went with cougar fans silent and effective !
Main Rig
Canadian Eh ?
[FS] GTX560Ti 448, 120mm radiator, 120mm/200mm fans... WTB/T: Modular PSU, i5 2500k bundle wonton1017 Buy/Sell & Trade 2 June 18, 2012 05:13 PM
[WTB] 200mm FAN Inik Buy/Sell & Trade 9 November 23, 2011 04:27 AM
cooler master 200mm ultraman7k Air Cooling 5 August 15, 2011 01:28 PM
Upgrading a 200mm fan mattydies Air Cooling 0 September 19, 2010 10:38 PM
[WTB] Looking for 200MM CM Sniper Fan xXxRithxXx Buy/Sell & Trade 10 April 15, 2009 08:14 PM
