<~----> Punctured Rad - Page 3 - Hardware Canucks
  #21 (permalink)
Old January 24, 2013, 09:46 AM
He originally said 68$ for the whoel thing, but i didnt have 68$, and since he knew i was in university, he dropped it to 40. Nice guy, highly recomended lol. Ill be advertising Cape Breton Auto-Rad for a while hahah
  #22 (permalink)
Old January 24, 2013, 10:00 AM
sswilson's Avatar
Originally Posted by Trocko View Post
So basically, they heated the corner, bent the metal back, soldered the hole shut, bent the metal back, and soldered it back... then spray painted that area... I dunno...
The rad does not leak anymore, but for 40$ i dunno haha, hopefully it was dont right and i wont have anymore trouble... Lesson learned, dont use 2" 6/32 bolts Off to home hardware for proper botls :P And a tap, because the hole is ******
Don't feel too bad, you're not the first and won't be the last to puncture a rad this way. It's such a common mistake that I made special mention of it in one of my build logs. If you want an excuse to pick up yet another tool.... some wire strippers also have built in screw cutters (screw threads into the strippers for cutting to length) which allows you to buy one size screw and then cut to size if required.
And yeah, $40 might sound like a lot, but it's a minimum 1 hr work and I suspect it might actually have taken longer than that.
  #23 (permalink)
Old January 24, 2013, 10:26 AM
Shadowmeph's Avatar
Glad to read that you got your rad repaired
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
  #24 (permalink)
Old January 24, 2013, 04:08 PM
"Quote This..."
That's cuz he knew he was gettin' some tonight.
And so is Jerry!
Black belt in CAPS LOCK.
