Originally Posted by Feanor For your cpu/goal/budget, a 240mm with high fpi, on which 3 high performance fans (1800-2000+ rpm) would be fitted, a rasa cpu waterblock (i own an ek supreme HF and a rasa, and they're really in the same ballpark) and a mcp 35x pump/res combo would do just fine. Choose your tubing and fittings color, fill your loop with distillated water and add a silver kill coil.
The whole setup should be under 200$, be easily customized to almost any case, and allow for your cpu to be pushed in the voltage red zone. At least that's what happened to me with the above on a i7 970. Now voltage is the limiting factor in my overclock. No way i'm gonna run 1,5 vcore 24/7! |
Okay cool Thanks! I'll take a look.
