Old January 17, 2013, 08:48 PM
CTA's Avatar
CTA CTA is offline
Default loud daz storm ddc 3.1?
i bought it a while ago after half broken pump with cracked reservoir... whatever...
DazMode STORM DDC 3.1 10W Pump
is that product really quiet? mine is very loud... i also can feel it away... it sounds like glubbb and roar or grr... then back to normal but still louder than originally i installed... like old laptop's half broken hdd's hdd...
i started to have that problem like 4 month ago... i dont know if its serious or not... i already got used of it...
do you have that problem?
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old January 17, 2013, 09:10 PM
Bungwirez's Avatar
both of mine make only a minor humm. sounds like its failing, but after four months and its still kicking IDK... you're sure its not just air trap?
If you don't like funerals, don't kick sand in Ninja's face
Old January 18, 2013, 03:17 PM
CTA's Avatar
CTA CTA is offline
i dont think so...
take a look at this video...
Download sound1.zip from Sendspace.com - send big files the easy way
dont know if that sounds clear to you...
Old February 18, 2013, 04:06 PM
Wow, that is grossly annoying. I think that is the nature of the pumps. I bought a few of the DDC pumps bmaveric was selling around the forums. They sound similar. Swiftec DDC pumps are almost whisper quiet.
very loud cpu fan - help please! cear965 Air Cooling 9 July 30, 2010 02:45 PM
my cpu is loud hohohee CPU's and Motherboards 19 September 1, 2009 04:26 PM
How loud is too loud for fans? Liu Kang Air Cooling 40 April 5, 2009 10:11 PM
loud pump kyle_L Water Cooling 19 January 26, 2009 05:24 AM
is the hdd supposed to be so loud? Bucklaz Storage 29 January 25, 2009 11:08 AM
