-   -   WIP Fraggallot a Prodigy (http://www.hardwarecanucks.com/forum/water-cooling/59094-wip-fraggallot-prodigy.html)
ZZLEE January 11, 2013 10:14 PM
What I need now is Courage.
I have all my parts I think ( hope ) :whistle:
The working bits are on cardboard humming in the background with the stock intel on them.
Time to unmount the rads from the case and flush the Radiators 200 mm and a 140 mm.
I will post picks an parts list
Is there a water block fore the ZOTAC 660 TI AMP!
concinnity January 11, 2013 10:28 PM
Looks like a stock 660Ti, so any should work. The ones from EK definitely do.
ZZLEE January 11, 2013 11:13 PM
my rads are brass and CPU block is copper.
( NexXxuS NVXP GTX670 copper ) think it will fit ??
maybe adventure
ZZLEE January 23, 2013 03:07 PM
Loop got water in it.
If there is red dot on the Board it will be glowing red.
running loop and drying out the board. :clap:
got to let it :(
ZZLEE January 25, 2013 05:42 PM
Fraggallot Lives :clap::bananafunky:
Trocko January 27, 2013 07:31 AM
cant wait to see some picks :P
