Old January 10, 2013, 07:08 AM
Default Mac Pro water cooling.
Hi canucks.
Its been many years since I last modded a case, this one is epic. I am glad to see there is a strong modding and hardware community in Canada.
So couple of months ago I had the chance to pick up a Apple 2006 Mac Pro. Still working with dual xeon 2.66ghz. I picked this case up and really had a hard time deciding if I should mod it because it was still working. Well once the screw drivers came out and 4 hours had gone by there was no going back.
So far I cut holes for the windows, cut holes for the mother board tray. I am almost finished mounting the mother board tray and its time to start thinking about the cooling.
Water cooling is a must, not sure what hardware will be in this case but for sure one cpu and maybe 2 gpus all water cooled.. With the space I have from the motherboard tray to the front of the case I can put dual 240 rad or extra think single 240 rad. I am thinking dual swiftech MCR220-XP or single Alphacool NexXxoS Monsta 240. what are your thoughts on that?
Next is pump, I still have a working Ehiem 1250. Is it worth upgrading to somthing like a D5 or ddc?
Last question I had is, where can I get aluminum 1"-3/4" corn beads or corner guards in . Like this pic
I will start posting pics of a work log once the rad is ordered and motherboard tray is mounted.
Aquarium gear for water cooling??? WATER CHILLER??? clshades Water Cooling 6 March 15, 2012 09:21 PM
New To Water Cooling mjbdc07 Water Cooling 10 August 31, 2010 05:25 AM
new to water cooling LacrosseTown Water Cooling 11 May 19, 2010 01:50 PM
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
