Old January 10, 2013, 01:39 AM
Default Loop Leaked
Hey all,
I installed a new reservoir and had to replace some tubes due to length. Well one of the connections leaked and water flowed down my mobo when I turned on the system. (fired up the pump)
Now I am getting a screaming, single tone, beep.
I have taken out all of the cards and noted moisture in all the PCI slots... It's drying face down right now...
Have I FUBAR'd my system? Any suggestions?
Intel i7 Quad Core 920 @3.8GHz | eVGA X58 x3 SLI | HAF 932 | Corsair 1000w | WD SSD 256gb | WD 3200 1TB | Seagate 2TB | 6x2GB DDR3 Mushkin XP3| eVGA GTX 570 HD| 24" BENQ E2400HD | 19" Samsung 953BW
Swiftech 655 | Swiftech MCR220 | Apogee GTZ+1366 | EK Spinbay Res | Primochill 5/8" | Bitspower Compression Fittings
Old January 10, 2013, 03:07 AM
sswilson's Avatar
Only time will tell. Do you have some canned air? That will help speed up the drying process.
Old January 10, 2013, 04:55 AM
Bungwirez's Avatar
get a big bag of rice and stick your mobo in it for a couple days.
If you don't like funerals, don't kick sand in Ninja's face
Old January 10, 2013, 08:21 AM
IRQ Conflict's Avatar
Methyl Hydrate. Never use water in a water cooled setup. Or so I've heard.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
Old January 10, 2013, 09:36 AM
I used air to get water out of the pci slots, ill be putting a fan on it today...
Old January 10, 2013, 11:51 AM
SugarJ's Avatar
Ya, having it on while wet probably toasted it. Let it dry for 24 hours and try again. You might get lucky.
Old January 10, 2013, 12:13 PM
So I dried everything, quad-triple-checked the connections and fired her up....
She is running fine, no issues and still at 3.8ghz (on a i7-920) at 48 degrees!
I got lucky today, thanks for all the help~!
Old January 10, 2013, 01:46 PM
KaptCrunch's Avatar
never smoke around that stuff you may just light up the place
Methyl Hydrate is flammable and is used in phase change loop
note: may attack some tubing
Old January 10, 2013, 07:20 PM
Ah! Yes. I never thought about it eating some plastics. Thanks for the phase change info. I didn't know that. Don't people use another type of non conductive (electrical) liquid in water loops these days?
@ Hail Caesar, glad you got that working again.
Old February 18, 2013, 04:15 PM
Distilled water with a silver coil is all I use and get great temps. Water stays nice and clear in rez.
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Crysis 2 Leaked Ryeguy151 Gaming 40 February 17, 2011 10:26 PM
Another loop order, single/dual loop thread... turtletrax Water Cooling 8 July 28, 2010 08:40 PM
Leaked Capacitor in my PSU? hen555 Troubleshooting 1 May 19, 2009 02:45 PM
ATI RV870 Leaked! th3b00m Press Releases & Tech News 36 May 18, 2009 01:57 PM
