-   -   Water Cooling Parts List + A Question (http://www.hardwarecanucks.com/forum/water-cooling/58909-water-cooling-parts-list-question.html)
Rollergold January 3, 2013 03:05 PM
Ordered or Already Owned:
Case: HAF 932 (Already Own)
CPU Block: Swifttech Apogee HD | Apogee HD - Rouchon Industries Inc., dba Swiftech - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit
GPU Block(s): 2x XSPC Razor GTX680 Full Cover Water Block Prepared for SLI With 7 G1/4 Ports Twin LED (New Style) | XSPC Razor GTX680 Full Cover Water Block Prepared for SLI With 7 G1/4 Ports Twin LED (New Style)
Pump: Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs | Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Radiator(s): Alphacool NexXxoS UT60 Full Copper Triple 120mm Radiator & Alphacool NexXxoS XT45 Full Copper Single 120mm Radiator| Alphacool NexXxoS UT60 Full Copper Triple 120mm Radiator - FrozenCPU.com | Alphacool NexXxoS XT45 Full Copper Single 120mm Radiator - FrozenCPU.com
Fans: 4x Gentle Typhoon AP-13's | https://www.dazmode.com/store/produc...db_silent_fan/
Reservoir: Swifttech Maelstrom 5 1/4" Dual Bay Reservoir | Maelstrom 5 1/4" Dual bay Reservoir - Rouchon Industries Inc., dba Swiftech - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit
Not ordered:
Tubing: PrimoChill PrimoFlex Pro LRT UV Blue 3/8IN ID 5/8IN OD Tubing (10 Feet) | PrimoChill PrimoFlex Pro LRT UV Blue 3/8IN ID 5/8IN OD Tubing (10 Feet)
Fittings: 3/8" ID x 5/8" OD compression fittings (Brand TBA)
SLI Fitting: TBA (Have not decided)
Coolant: Ek Water Blocks Fluid UV Blue NON-CONDUCTIVE Water Replacement for Liquid Cooling 1000ml | Ek Water Blocks Fluid UV Blue NON-CONDUCTIVE Water Replacement for Liquid Cooling 1000ml
Any suggestions, changes like bigger tubing or a different rad or does this look like a good list? I'm open to just about any change in the list.
My objective with this loop is to silence my system as much as possible without any compromise to my current CPU overclock. The case and everything else I already own so don't worry about that not being listed.
Oh and my question is what is a so called pump top and is that something I should consider for the pump I listed?.
botat29 January 3, 2013 03:17 PM
This radiator will never provide cooling for a CPU + 2 x 680 , you can also have a koolance 380 or a EK Supremacy for about the same price as this swiftech. But before going more far, What is your case ?
Rollergold January 3, 2013 03:18 PM
HAF 932
Rollergold January 3, 2013 06:30 PM
What radiator would you recommend then?
Pabz0r545 January 3, 2013 06:56 PM
That radiator will cool your system but I wouldn't expect amazing temperatures or extreme clocks or anything. Also if you are aiming to silence your system you will want to go with a low fpi radiator optimized for low speed fans and silence. Maybe AP14's or 13's. Something like Alphacool NexXxos UT60, XSPC RX 360 or another fatty low fpi rad.
Also like stated above it is recommended to have 120mm of rad per block + 120mm extra radiator.
The pump top is mainly just for looks and sometimes to attach to a reservoir.
Masteroderus January 3, 2013 08:42 PM
The radiator should be able to cool three high heat components. However, you will probably have to run your fans and pump at full speed, and fans at full speed, and you won't get extreme temps.
Rollergold January 4, 2013 02:55 PM
Thanks for all the responses. Got another question, I'm currently considering 3/8"ID x 5/8"OD tubing & fittings. Should I go to 3/8"ID x 1/2"OD tubing & fittings so I increase the flow rate or should I just upgrade to 1/2 inch tubing?
Pabz0r545 January 4, 2013 03:57 PM
The tubing size is mostly aesthetic. Personally I go with 3/8-5/8. I feel like 1/2 - 3/4 would pose some clearance issues on certain blocks where the inlets are spaced closer.
sswilson January 4, 2013 04:14 PM
The ID is the inner wall so there would be absolutely no difference between 3/8"ID with either 5/8 or 1/2" OD tubing other than how it reacts to bends in the loop.
As has been suggested above, going to 1/2" vrs 3/8" ID is more for asthetics than anything else, however if you plan a complicated loop, 3/8" is a hell of a lot easier to work with once space becomes an issue.
Rollergold January 4, 2013 04:37 PM
Sounds good I'll stick with my current size of tubing then.
