Old January 5, 2013, 07:24 PM
Rollergold's Avatar
Does anyone own the Maelstrom res I'm considering? If so can an LED be mounted in the res? Since I'm just considering the use of distilled water the glow of an LED for the res is something I would like to have to keep with the blue theme.
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
Old January 5, 2013, 08:42 PM
sswilson's Avatar
From the same page you initially linked to......
Old January 5, 2013, 11:38 PM
Rollergold's Avatar
Attachment 18392
Woops sorry about that.
Old January 6, 2013, 05:57 AM
sswilson's Avatar
Heh... no problem. It's not like they made it easy to find. That's quite the wall of text/info they've got going on over there. :)
Old January 10, 2013, 10:21 PM
Id recommend the black ice sr1 with with ap-13's, ap 15s are loud, i have my system with ap-13's.
Old January 12, 2013, 05:44 PM
Rollergold's Avatar
Got another question. I was looking at other low FPI rads and I came across this:Alphacool NexXxoS UT60 Full Copper Triple 120mm Radiator - FrozenCPU.com
Has anyone had any experence with UT60 rad's from Alphacool?
Reviews seem to show similar performance compared to the Black Ice SR-1 and the XSPC RX360.
Old January 12, 2013, 06:19 PM
lowfat's Avatar
UT60 is considered among the very best radiators out there.
Old January 12, 2013, 10:09 PM
ZZLEE's Avatar
add to your list silver tape or silver wire to kill algae and biological in your loop, important fore distilled water.
Or use a few silver fittings in the loop.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #19 (permalink)
Old January 13, 2013, 03:08 PM
Rollergold's Avatar
Would 4 silver fittings be enough?. 2 on the Res and 2 on the Rad(s) and do you have any examples of compression's that are truly silver plated? I see a lot of chrome plated ones that have silver in brackets but they don't say on the spec list if they are truly silver plated or not. Also I've decided to use dedicated water cooling solution instead of just pure distilled water so I can have an easier time in seeing how much fluid is left in the res (the one I ordered has coolant level monitor). Haven't decided which coolant brand to buy so I'm open to suggestions.
  #20 (permalink)
Old January 15, 2013, 12:37 AM
Rollergold's Avatar
Seems hard to find true sliver plated fittings for my tubing size so I've decided to just buy 2 .999 sliver G 1/4 plugs and use them on the extra 2 inlets on my Maelstrom bay res.
Also I've heard around about using sliver coils contributes to corrosion on nickel plated products, is that true? The EK blocks for my 680's are nickel plated IIRC and if the following below is true sliver coils will void the warranty on my EK blocks
Please, note that use of Silver Coil voids warranty for Koolance and EK Waterblcoks products.
Source: https://www.dazmode.com/store/produc..._25mm_-_250mm/
water cooling check list QuickDeath Water Cooling 10 February 13, 2012 07:07 PM
Looking For Water cooling parts Phobia Buy/Sell & Trade 10 May 29, 2009 11:23 PM
WTB water cooling parts? Liu Kang Water Cooling 13 March 25, 2009 06:16 PM
[WTB] WTB: Water Cooling Parts Aj23 Buy/Sell & Trade 1 March 5, 2009 12:42 PM
List of Water Cooling Guides rk Water Cooling 0 February 18, 2009 01:09 PM
