Old December 24, 2012, 09:43 AM
Ok so I took it apart and went back to the single pump as using two in serial wasn't producing the results I needed. It did though have a spot to attach a res to it but that's it. Either the bubbles will work themselves out or I will try to tip the case to get the one out of the gpu. It is stable and not leaking which is good.
Old December 24, 2012, 10:23 AM
Shadowmeph's Avatar
what I do is move my pc to a place where I can actually turn it back and forth from the res side to the rad side I keep doing this with my pump at full with my pc turned off and nothing connected to it, it takes me anywhere from 30secs to 5 mins to get all of the air bubbles out and I am running to 240s and a dual bay res
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old December 24, 2012, 01:44 PM
It would be almost simpler if I could get one of those swiftech radiators with builtin reservoir and pump mount.
Old December 24, 2012, 01:47 PM
those can be just as troublesome.
Give us a pic of your system and might be able to see something for ya.
Old December 24, 2012, 01:54 PM
Really? I'm curious how well it performs. Either way there it is. I'm at work right now but the green thing on the right is the 360 radiator.
Old December 24, 2012, 02:41 PM
Shadowmeph's Avatar
oh one thing that I didn't mention is that after moving my PC around trying to work out the air I open the fill part of my res so that the air can actually get out and with it open and the pump still running I move the PC around a little more just remember that the air will go to its highest possible position but if there is water weighing it down it cannot move.
Folder :
Old December 24, 2012, 03:19 PM
KaptCrunch's Avatar
well i see one thing for sure the front rad is higher then the rez
IMHO i would place rez on top of computer as working ornament for can fill easy and bleed also sight if water moving, pass lines on top and top of rez is fill port
i'm not seeing rez clearly ...where's the suction and return?
pump>front rad>cpu>gpu>lower rad>rez
do you hear marbels when pump is running?
for those bubbles aren't good in your rez
Old December 24, 2012, 03:37 PM
You need to take some better pics. That pic only shows half the story.
Like where is the line from the CPU heading off to?
Why is there 3 lines on the bottom of the reservoir?
How is the radiator setup?
Get me more pictures as from what I can tell from this horrible picture you don't have this loop setup properly.
  #19 (permalink)
Old December 24, 2012, 04:02 PM
Yeah I know the picture isn't the best. I can only do so much with a cell phone camera.
There's only two lines going to the res. That third line is the pump going to the 360rad. And the line from the cpu goes to the 360 rad. Right now it is setup as pump> 360rad> cpu> gpu> 120rad> res> pump. When I get time to look at it again I might drill mounting holes for the rad behind the case and get rid of the 120 rad. This is a work in progress. This is definitely not the final build.
  #20 (permalink)
Old December 24, 2012, 04:18 PM
I don't care about quality I want quantity. And from it sounds you've got your inlet/outlet at the top of the case which is a HUGE no no.
But again pics will say a lot.
Reservoirs/Pumps: Need a little bit of help... JORD4N Water Cooling 3 March 10, 2011 09:38 PM
Anybody tried Danger Den pumps? Dazmode Water Cooling 21 July 12, 2009 03:50 PM
New DD pumps @ NCIX Cptn Vortex Water Cooling 20 September 4, 2008 07:20 PM
2 pumps ? Wasza Water Cooling 10 December 13, 2007 10:17 AM
