Old December 8, 2012, 12:00 AM
Default Silverstone AP's for rads?
I was wondering what you guys thought of using Air Penetrator's for radiator cooling. I plan to use them in a pull configuration only.
I read that the AP's don't do well for pushing, as they shoot air in a cylindrical shape, but I heard that they pull fine.
Can anyone confirm?
Thanks
Old December 8, 2012, 04:52 AM
KaptCrunch's Avatar
was made for air intake for cases does well but close up poor pressure use a fan spacer an seal pressure side of fan to exit side of rad
Old December 10, 2012, 08:08 PM
So you're saying use fan spacers and seal off the sides of the fan or what?
Old December 11, 2012, 06:50 AM
concinnity's Avatar
Air Penetrators are great for rads- Linus himself uses them
Getting information off the Internet is like taking a drink from a fire hydrant.
Old December 11, 2012, 10:57 AM
dustin1706's Avatar
Yeah, APs are good fans for radiators. I used to use them myself but found similar RPM noctuas and gentle typhoons to be quieter.
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old December 11, 2012, 11:16 AM
Soultribunal's Avatar
Can anyone confirm?
Thanks
The AP is an average Fan for Radiator/CPU Cooler usage. At Max RPM it puts out a paltry 1.02mm h20 for static pressure.
Where as a Coolermaster R4's for being such a cheap fan can put out 3.04mm h20 in direct comparison (though they will be a bit louder than an AP).
Even a Blademaster from CM can put out almost 4mm h20 static pressure on a rad. This is important, as rads care more about static pressure than CFM. It is there ability to force air through the tight confines that makes them work well.
So, although you can use the AP's if you like that style of fan, there are better options out there.
-ST
rads... how much of 'em? MG2R Water Cooling 9 December 8, 2012 06:55 AM
mixing rads Raftus Water Cooling 3 December 8, 2012 04:30 AM
D5 w/ EK top + 3 x 360 rads Prolab Water Cooling 6 October 21, 2011 07:14 PM
[WTB] Thermochill rads Frank Booth Buy/Sell & Trade 0 March 20, 2009 06:08 PM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
