Old December 5, 2012, 09:10 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Corsair Hydro H60 & H55 Review Comment Thread
Corsair's Hydro series is getting a minor refresh with the H55 and new H60 taking over from the previous generation's H50 and H60 respectively. Priced at just $70 and $80 they target the entry-level gamer who wants increased cooling performance for overclocking and easy installation.
Read more here: Corsair Hydro H60 & H55 Review
Old December 6, 2012, 02:19 AM
Good review, sounds like there good units ...
my only problem with the review to note ...... lists/mentioned AMD 1090T rig in test setup ... but no results for the units on it.
Old December 6, 2012, 06:01 AM
Soultribunal's Avatar
I think you can sum up the H60 by saying 'Balance'. It is a blend of being good enough for everything one can hope to achieve for that price point. I really think the refinement of these AIO's has come a long way, and Corsair has helped pioneer that with its partners.
Going to agree that the H55's mounting design is antiquated....after all my H50 uses that, and that is over 2 years old now....Astek needs to update how they retain these to the board.
-ST
Old December 6, 2012, 06:10 AM
SKYMTL's Avatar
You are correct. It was used for the AMD Installation portion but it shouldn't be in the Test System area.
Old December 6, 2012, 10:29 AM
Varroa's Avatar
Any idea if installing the rad upside down will void your warranty? When I installed my Coolit eco that way I was told it voided my warranty and it was the reason it failed.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old December 7, 2012, 08:33 PM
Galcobar's Avatar
I notice the installation description for both models are explicit in including LGA 775 as a supported socket, but neither of the specification tables list it among the Intel sockets.
The installation photos for the H55, at least on my screen, aren't quite large/sharp enough to read the notation on the backplate bracket for which holes to use for which sockets.
On a related note, what about compatibility for FM2, which is also not listed among the supported AMD sockets (I can't recall having seen anything authoritative on whether or not FM1 and FM2 use the same mounting dimensions for coolers)?
Typo noted: dual fan chart subtitle "... Inisde a Case"
Old December 7, 2012, 08:47 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Good catch Calcobar on the chart. It has been updated.
I will check again on the sockets supported. It could be that between the product brief I received early on and the final product that 775 was dropped...and it simply slipped through the cracks.
EDIT:
Damn. Just checked the hardware and you are indeed right, 775 for BOTH the H55 and H60 got dropped somewhere along the way. Its now only AMD and Intel 1155/1156/2011 sockets that are supported out of the box. VERY strange for Corsair to drop support like this.
I apologize for this and have notified Skymtl to make the necessary corrections to the reviews.
Old December 7, 2012, 08:56 PM
It will fit the FM2 as it is the same socket as AM3, AM3+ with different pin count. I've had H100 on A10-5800k and FM2 isn't listed for it
AMD Phenom II X6 1100T ASUS Sabertooth 990FX
8 Gb Patriot PC3-15000 DDR3
ASUS HD6970 2Gb Direct CUII Corsair HX650
Corsair Force SSD, Seagate Barracuda 500 GB 7200 rpm SATA HD
Samsung 22X DVD Writer SATA w/Litescribe
Corsair H80
Antec 900 II case
3 x ASUS 25" monitors
Corsair Hydro Series H100 Liquid CPU Cooler Review Comment Thread SKYMTL Water Cooling 26 May 7, 2012 04:54 PM
Corsair Hydro Series H80 Liquid CPU Cooler Review Comment Thread SKYMTL Water Cooling 5 October 6, 2011 08:05 PM
Corsair Hydro H70 CPU Cooler Review Comment Thread SKYMTL Water Cooling 64 January 26, 2011 02:21 PM
Comment Thread for Corsair HX620 PSU Review SKYMTL Power Supplies 25 September 29, 2009 05:49 AM
Corsair TX750 PSU Review Comment Thread SKYMTL Power Supplies 22 March 25, 2008 02:02 PM
