Thermal Capacity of Radiators Wondering if there is a rule for the thermal capacity of radiators. What are the benefits/drawbacks to higher or lower FPIs? Does a slim radiator with a high FPI have a similar thermal capacity to a thick one with a low FPI? |
A general rule is that you get a 120 per component you are running in the loop. For example, in my loop, I am cooling my CPU and GPU, so a 240 rad is the minimum to get (I am actually using a 360 rad in the loop). With FPI, the more the better, however with more FPI, you need higher performing fans to push air through the tight space. Rads with lower FPI can be used with low speed fans. And in terms of thermal capacity, each rad is different, but the thermal capacity of it also depends on what fans you have pushing air over it. If you have a slim rad w/ high FPI with slow fans on it, your loop will run really hot, as the fans cannot push enough air through the rad quick enough. Hopefully this helps a bit. |
Thanks |
Just like keltron says it depends on your goals. And a 120 per component is a good rule for minimum rad requirements. A higher FPI rad has more surface area, but is more restrictive so it requires more air movement meaning faster, generally louder fans. However, it has more cooling potential if you can give it enough air. A low FPI rad has less surface area but can be adequately cooled by very slow, quiet fans. Also bear in mind that some rads are thicker than others. A thicker rad will have more surface area compared to a thinner one with identical FPI. Skinnee labs has some good objective radiator reviews and comparisons. Radiators | Skinnee Labs |
Keeps my temps in check real well, and I don't need high-speed fans with it. |
Thanks for the help |
| All times are GMT -7. The time now is 09:00 AM. |
