-   -   Mayhem Dye with Fesser cooling fluid (Dazmode protector) (http://www.hardwarecanucks.com/forum/water-cooling/57617-mayhem-dye-fesser-cooling-fluid-dazmode-protector.html)
magiwizard October 30, 2012 06:56 PM
So as title says I purchased the two without thinking about whether it will pose a problem to use Dazmode protector with Mayhem's clear / UV blue dye.
If anyone knows (or is using) the combination please let me know :)
lowfat October 30, 2012 07:04 PM
I am to guess that it will be a problem. Dyes tend to breakdown when the pH of the water is too low/high. Adding other chemicals to the loop will definitely affect it. The safest thing to do would be to use a piece of silver as a biocide.
Hmm, just noticed you said clear dye. Can a clear 'dye' actually breakdown? I would still suggest avoid mixing the two.
Bungwirez October 30, 2012 08:07 PM
Mayhem Red dye and dazprotect went from A to B in 6 days.
http://i249.photobucket.com/albums/g...2/P1020823.jpg
http://i249.photobucket.com/albums/g...2/P1020838.jpg
lowfat October 30, 2012 08:15 PM
Same thing happened to me when I mixed PTNuke (copper sulphate) and Mayhems red.
magiwizard October 30, 2012 08:22 PM
Contacted dazmode to see if he can change the order.... just made the order like an hour ago so hope he reads it before sending it out =/ ... side note hope it arrives close to the same time still lol... I leave town 2 days after the stuff arrives and want to build it before leaving lmao
Cheers and thanks for the quick response
Sidenote,
Daz responded within 30 min of contact now that's customer service :o
Dazmode October 31, 2012 11:45 AM
Seems organic coloring does not play well with industrial chemicals. Thank you for sharing.
