<~----> Corsair Intros Updated Hydro H60 & New Hydro H55 Liquid CPU Coolers - Hardware Canucks
Old October 25, 2012, 07:03 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Corsair Intros Updated Hydro H60 & New Hydro H55 Liquid CPU Coolers
New Hydro Series CPU coolers take advantage of the latest technology to provide higher cooling performance and lower noise levels.
Corsair’s Hydro series of sealed system liquid CPU coolers is one of the most popular around and a number of their more affordable options are getting an update.
Read more here: Corsair Intros Updated Hydro H60 & New Hydro H55 Liquid CPU Coolers | Hardware Canucks
Old October 25, 2012, 07:12 AM
supaflyx3's Avatar
Do we really need these many coolers, that are only 1-2 degrees apart?
Old October 25, 2012, 07:18 AM
SKYMTL's Avatar
Sure. Why not? As they say: "Variety is the spice of life".
Old October 25, 2012, 08:07 AM
any confirmation of what the new tubing size is? that block/pump would likely be good for some simple modded loops with an extra (or bigger) rad
Old October 25, 2012, 08:38 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
The H60 2.0 appears to be CoolITs latest and greatest. Whereas the H55 appears to be Asetek's. It is very nice to see Corsair branch out and include BOTH mfg'ers in their lineup....as both bring different strengths (and weaknesses) to the table.
Old October 25, 2012, 12:37 PM
Soultribunal's Avatar
I really hope this generation of coolers is even an improvment on what I was used to in the past.
I think they have really refined these coolers, and so far from my experience they are really reliable and take the worry away from me for cooler heights, and RAM Heatsinks etc etc.
That being said, I really honestly think they should start making 140mm Versions since a lot of cases nowadays are opting for 140mm vs 120mm...
-ST
Old October 25, 2012, 02:13 PM
slippy's Avatar
Mmm nice tubes. Hope the fan isn't too loud.
AMD A10 5800K | MSI FM2-A55M-E33 | Asus 7750 1GB
4GB G.SKILL Ripjaws | 500GB WD Blue; 2TB WD Green | Corsair CX500
Cooler Master Elite 430
Old October 25, 2012, 02:31 PM
EmptyMellon's Avatar
Hope they refined the AMD mounting system, the V1.0 was pathetic at best. Sadly, it does not take a genius to design a nice mouting plate set-up, instead of this 'capt'n hook' design, just to save $1.50. Ended up replacing my H60 (on the home machine) with an 212 EVO, as the H60s I had up to this point were anything but quiet and definetly not suited for a quiet environment (my experience only of course). [The H80 for the work machine is fine.]
Old October 25, 2012, 05:18 PM
lowfat's Avatar
Shame they don't show the actual radiator. The original H60s radiator had a fin density that was way too high. Hopefully they fixed that major flaw.
Old October 25, 2012, 07:51 PM
Arrow Check out the link from TechPowerUp for H55 and 60 fin details
Check out the link from TechPowerUp for H55 and 60 fin details: Corsair Debuts Updated Hydro Series H60 and New Hydro Series H55 Liquid CPU Coolers | techPowerUp
Corsair Hydro Series H80 Liquid CPU Cooler Review Comment Thread SKYMTL Water Cooling 5 October 6, 2011 08:05 PM
Corsair Announces Availability of New Hydro Series Liquid CPU Coolers Sam_Reynolds Press Releases & Tech News 18 July 7, 2011 08:13 PM
Corsair Announces New Hydro Series Liquid CPU Coolers Sam_Reynolds Press Releases & Tech News 21 June 6, 2011 02:23 PM
