Old October 25, 2012, 03:54 PM
KaptCrunch's Avatar
Originally Posted by sswilson View Post
Your memory isn't failing you, that was my initial line of thought, but it evolved into a drain tube which should make life a lot easier.
or do a syringe with tubing to suck out fluid of rez since its in the lowest point
Question about drain Hose fyshawk New Builds 2 June 22, 2012 05:38 PM
Drain port martin_metal_88 Water Cooling 21 June 14, 2010 06:37 PM
Cooler Master Presents a New Flagship to the High Air Flow Line: HAF X mikellini Press Releases & Tech News 12 May 28, 2010 04:13 PM
Circuit City Flushed Down the Drain FiXT Press Releases & Tech News 23 January 22, 2009 10:02 AM
drain???? WolfBane Water Cooling 29 July 13, 2008 09:10 AM
