Switching Reservoir Help needed thanks Ok here we go so if i am wanting to switch from the Dual 5.25" Bay Reservoir to the Tube Reservoir what all will i need just so i know better to ask then buy first ask later This is the Reservoir i have now below STEP ONE RAYSTORM KIT BASE - DUAL BAY D5 i am wanting to switch from my Dual 5.25" Bay Reservoir to this one Bitspower D5 Pump Top (Acetal Version) I know i will need a pump top but if someone could help me out it would be great things I have The D5 pump New HEATKILLER CPU Kuhler Rev3.0 1366/2011 Black Nickel compression fittings 7/16″ ID, 5/8″ OD Clear Tubing EX360 Radiator with 3 Triebwerk 55mm Optimized Radiator Fans everything going into a Corsair 800D case |
I'm confused as to what you're asking. It looks like you have chosen your pump top already? |
http://ep.yimg.com/ca/I/sidewinderco..._2227_18173385getting rid of the dual bay to make room for burners yah just need longer hosing and are fittings same hose size |
ok getting confused here i have the DazMode STORM D5 Strong pump now i want to go to tube Reservoir Now my question is what are the parts i need to do this As of now my pump is in a dual bay res |
http://i20.photobucket.com/albums/b2...loded-view.gif the ring is threaded turn counter-clockwise to loosen pump from body, be careful of the 0-ring |
this kit (what KaptCrunch is showing): https://www.dazmode.com/store/produc...n_tinted_tube/ plus maybe one of these, optional: https://www.dazmode.com/store/produc...g_kit_-_black/ |
| All times are GMT -7. The time now is 06:46 PM. |
