  #21 (permalink)
Old January 3, 2013, 05:58 PM
botat29's Avatar
I was referring to only using a 360 . with both you are ok
  #22 (permalink)
Old January 4, 2013, 03:54 PM
thank you.... i am just waiting for that other build log to finish ... it looks pretty nice i might do it
  #23 (permalink)
Old January 11, 2013, 03:02 PM
will it matter if the front 240 and top 360 are not the exactly same radiator? (only difference being in lenght....240/360?). If i put a slim on the top but not on the front what changes will that cause? and will it cause any problems
  #24 (permalink)
Old January 22, 2013, 05:18 PM
r0k0's Avatar
im currently making my 600T a watercooling setup in it, a 240 rad will not fit in the front, you'll need to order a 200mm rad for the front..
im putting a 360 on the top and will try to find a 200mm rad for the front
previous setup was 1x 240 and 1x 120 and temps werent so low gpu was hella low but cpu got a bit higher
so hopefully with the 360 and a 200mm i will lower alot if i cant find a 200mm i'll use my 120 for the rear
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
  #25 (permalink)
Old January 29, 2013, 11:43 AM
look at the build on page 2.....
Water cooled laptop rfglass Water Cooling 6 March 24, 2012 07:08 PM
Level 10 GT water cooled HiTi Water Cooling 4 September 23, 2011 04:58 PM
Completed My water cooled 800D! jporter91 Case Mods, Worklog & Gallery 18 February 7, 2011 06:32 PM
Water-cooled folding rig chrisk Water Cooling 17 December 26, 2009 10:05 AM
Antec 900 Water cooled....but need help oksir Water Cooling 9 August 25, 2008 10:25 PM
