Old December 27, 2012, 03:28 AM
can anyone provide a link to the same or similar build someone has done?With none or as little modifications to the case as possible.
Old December 28, 2012, 09:39 AM
Bungwirez's Avatar
IMO one 360 rad is enough to cool your CPU and GPU.
Resident Modder BigFoig has a nice build log for the 600T here... you shouldn't fear the Dremel!
Corsair 600T SE Watercooled; internal triple radiator mod
If you don't like funerals, don't kick sand in Ninja's face
Old January 1, 2013, 04:16 PM
but keep in mind my card is a dual GPU card
Old January 2, 2013, 07:10 AM
BigPhatPaulie's Avatar
It will still be fine
FOR PONY..... that is alll
Old January 2, 2013, 05:36 PM
what do u mean fine? what kind of temps are we talking about here with the triple on the top and dual in the front?
Old January 2, 2013, 07:29 PM
From what I've seen and read, you want 1fan for every component... So in your case a 360 which has 3 fans (not counting push/pull) would suffice... Having a 360 rad plus a 240 would be more than enough rad surface.... Hard to say what the temps will be... That my friend is just more research but going by that rule of thumb you'll be fine
Old January 3, 2013, 07:17 AM
concinnity's Avatar
A rule to follow is: A 120mm of radiator per chip, plus one extra.
Getting information off the Internet is like taking a drink from a fire hydrant.
Old January 3, 2013, 07:21 AM
concinnity's Avatar
A 360 and a 240 would definitely run a CPU & Dual GPU loop no problem. Couldn't give you temps though, I've no experience with multiple chips.
  #19 (permalink)
Old January 3, 2013, 07:50 AM
botat29's Avatar
from what I have experienced, 1 CPU + 1 GTX 580 is the limit of a 360, so a cpu + GTX 590 will have high temps for sure.
  #20 (permalink)
Old January 3, 2013, 05:41 PM
with both the 360 and 240?
Water cooled laptop rfglass Water Cooling 6 March 24, 2012 07:08 PM
Level 10 GT water cooled HiTi Water Cooling 4 September 23, 2011 04:58 PM
Completed My water cooled 800D! jporter91 Case Mods, Worklog & Gallery 18 February 7, 2011 06:32 PM
Water-cooled folding rig chrisk Water Cooling 17 December 26, 2009 10:05 AM
Antec 900 Water cooled....but need help oksir Water Cooling 9 August 25, 2008 10:25 PM
